MAF Sensor and Throttle Body Cleaning DIY: GS400 & GS430
Old 06-29-10, 06:14 PM
  #46
peterwho
peterwho's Avatar
Old 06-29-10, 06:34 PM
  #47
MrG4Life
MrG4Life's Avatar
^^ How long is after? It can take awhile for it to go back down after the cleaning.
Old 06-30-10, 06:03 AM
  #48
peterwho
peterwho's Avatar
oh it was right after.. it went down to the 9 mark
Old 06-30-10, 06:04 AM
  #49
peterwho
peterwho's Avatar
oh wait.. yeah it is at the 9 lol. but that was right after the cleaning
Old 08-08-10, 01:08 PM
  #50
chunkyda
chunkyda's Avatar
Question for y'all.
After reading this thread, I got a can of spray; CRC Mass Air Flow sensor cleaner (No. 05110) and read through the steps on the back... #10 DO NOTuse on vehicles with Karman-Vortex air flow , e.g. Toyota Supra Turbo, Mitsubishi, and most Lexus vehicles.
I found the answer on a toyota celica as well as prius forum which have the same part number. The 05 LS 430 has a hot wire sensor which is OK to use the CRC spray.
Old 08-09-10, 09:46 AM
  #51
alexulan
alexulan's Avatar
Originally Posted by chunkyda
Question for y'all.
Not sure. I did use it on my 2000 GS400 MAF with no problem.
Though If I did read the warnings I probably would not have.
Good thing real men don't read directions!
Old 09-20-10, 02:53 PM
  #52
400DGRZ
400DGRZ's Avatar
Question for y'all.
Alright so is it or is it not OK to use on 98-00 GS400s? Please chime in guys!
Old 10-02-10, 11:16 PM
  #53
94Supra
94Supra's Avatar
anyone know the 06 gs430's MAF,is it hot wire type?
and I know for sure above info about Supra turbo been Karman-Vortex is wrong (hot wire) NA Supra 2JZ-GE as in IS/SC 300 indeed are Karman.
Old 03-03-11, 09:27 PM
  #54
DND
DND's Avatar
Sorry to bump an old thread, but I'm planning to clean out my MAF and TB this weekend. From what I read here the 430 TB is electronically controlled. Could it be cleaned, like really get in there with my finger? Would hate to find out something broke when all said and done. Thanks
-Dane
Old 03-04-11, 06:43 AM
  #55
Debonair
iModerate
Debonair's Avatar
I have cleaned my 430's TB several times without an issue. I spray the cleaner on a cloth and then use my finger inside the cloth to clean the TB. The first time I did it I had to use a tooth brush on a few spots but it all comes off really easy now.
Old 03-04-11, 11:14 AM
  #56
silos5
silos5's Avatar
cleaned my LS400´s (1998) TB. I diceded to take it off. There was more dirt on the inside side, so my advice is to take the TB off. Dont forget to change the gasket, its not expensive. Turned on the engine and rpm´s are good now (they were too low before).
Old 03-04-11, 11:53 AM
  #57
DND
DND's Avatar
Debonair, thanks for the info. Feel more confident about my weekend job now.
I'll try to post some pics of the 430's MAF since it's slightly different from the 400 pics I see here.
-Dane
Old 04-05-11, 10:33 AM
  #58
philllyj
philllyj's Avatar
I need to try this, I have an 92 SC300 that displays Seattle's symptoms. Probably do it this weekend. Great write up
Old 11-13-11, 11:22 AM
  #59
Lexozz
Lexozz's Avatar
I cleaned my TB and MAF sensor today on my '98 LS and oh what a huge difference. Ever since I had the car the idle never seemed right compared to my past '95. When I started her up it actually idled @ 1100 rpm which is normal for cold start and then drop back down to about 500 rpm after she warmed up.
Got to give thanks to the OP and CL!
Old 12-11-11, 01:39 PM
  #60
Mr Johnson
Mr Johnson's Avatar
Was getting around 14 MPG lately on my 2000 GS400 when it used to be higher (16 1/2 or so). Broke down and did the MAF and TB cleaning. MAF was filthy the TB not so much. First 1/4 tank average is now around 17 MPG. Nice gain from an easy DIY.
Quick Reply: MAF Sensor and Throttle Body Cleaning DIY: GS400 & GS430
