serpentine belt change
i looked on here for 2 hours and i cant find it , i found it before can someone please help me . i want to change my belt on a 2000 gs 400 tommorow thanks
Try these posts for pics with the V8 serpentine belt schematic:
https://www.clublexus.com/forums/sho...hreadid=109469
https://www.clublexus.com/forums/sho...d.php?t=121862
Bingo!! Seven pulleys. Good find Seattle!
Gs 300 Serpintine Belt Change
Just as a side note. The tensioner on the GS 300 doesn't have a reverse threaded bolt. Here's how you relieve tension: take a 14mm socket with a large socket wrench and act as if you are tightening the bolt on the tensioner wheel. The leverage action of turning the bolt will make the tensioner twist and relieve the tension. From there remove the belt from the power steering pulley first (it's on the top right of the engine). Take the old belt off, throw it away, route the new belt (on everything but the power steering pulley), release tension again using the same technique, then slide the belt over the power steering pulley. Make sure everything looks to line up well and that you didn't loosen the tensioner wheel bolt in the process and you are good to go.
1999 GS 300 - Silver
2004 GX 470 - White
2004 GX 470 - White
