ATF drain plug/crush washer
i just started doing a Drain/refill on my 98 gs 400 and i jus bought a new drain plug with about 4 new crush washers. i was wondering if i can re-use the crush washer a couple of times or do i have to use a new washer everytime i undo the drain plug?
It is ok to re-use the same washer when you are doing multiple drain and fills. I would however use a new once you are done with your drain and fill cycle and ready to drive the car for an extended period of time. (i.e. one full tank of gas)
For piece of mind check your garage floor or parking spot for any oil leaks. Also, make sure your transmission is filled to the "full hot" hashmarks on the dipstick and the transmission is at normal operating temp, engine on, and car parked on a level surface when you check the fluid level. If the transmission is over or under filled it WILL act up on you....
thanks guys , i didnt wanna really re-use it but i thought i''d ask .. . .
and yes they are really cheap so its not worth any leak . .
dam when i took the drain plug off and the fluid came out , i thought i pulled the oil drain plug cuz my shiet was so dam dirty !! . ... i did 4 drain/refills and now its turning on the red side . ..thank god !
gemigniani
ES - 6th Gen (2013-2018)
26
09-03-24 02:11 PM
schmoozer
04-29-13 04:58 AM
