DIY : Serpentine Belt "hope this helps"
Thanks for the info guys.
Now, the loosening part is clear.
How much do I tighten the tensioner bolt once the new belt is installed?
My guess is just enough to put the tensioner back in place, then it will self correct once the engine is running?
as you tighten the tensioner bolt, clockwise the bolt should would only have a limit of tightening it til the tensioner pulley releases the belt again .. counter clockwise would just remove the bolt .. which you dont want to do
iModerate
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
and also needed when maintencing as said earlier .. the reason why i changed mine because it was gettin old.. and strechen and yeah it was sqweeking like a crazy horse when i accel =x
I just changed mine with Gatorback belt.
I've never done a belt change before, and it took about 5 min.
I got the belt from Amazon for $38 I think.
Toyota dealer quoted me $188, and the mechenic guy said it's pretty hard to change it and it would take 1 hour. What a BS!
I checked 3 other shops and dealers, and they all wanted between $160 to $200.
Thanks to all who provided useful info.
