No Power from Radio Help!!!
I have a problem. I had an panasonic radio installed and all of a sudden the screen just went blank and the power shut off. Im thinking maybe the radio malfunctioned. I then isntalled my factory pioneer radio and Im still not getting any power. Im not sure what the problem can be but I know it isnt the radio. Do you guys think its the fuse? If so where is it located on the car. What do you guys suggest. Thanks
P.S. Its killing me driving around in silence lol...
No i didnt check the fuse yet. Im not sure where the fuse is located for the radio. Is it at the driver side in the engine compartment Fuse 41. A friend of mine was tellin me that. Just want to double check with you guys. Also how do u tell if the fuse is blown?
![](http://mobmov.org/manifesto/fuse.jpg)
thanks man. i dont think its the radio because both of the radio's doesnt work. ill check that out tomorrow when its light outside. Also how much do you think a new fuse will run me?
no prblem. i could probably get a better idea if i had the radio in front of me, but anyway, check the fuses out first. new fuses aren't that expensive. you could probably get a 5-pack for like $2 at radio shack. not sure though. it's been awhile since i've had to buy any.
Pull the radio unit out.. (instructions http://bananags.grantham-internation...IY/remove_head)
Pull the radio towards you, sit in the passenger seat while doing this, turn the face of the radio towards the drivers seat. This should expose the rear (passenger side) right side of the radio unit and there should be (or should be) two circular plugs that go into the spot right in the middle on that right side. One should be larger than the other... One is the radio antenna and the other is the power to the unit. Check and see if both are plugged in, if just one is, follow the cable as the two are attached about four inches back. If there are no circular plugs in and you see two empty holes, then look around behind the radio for the cord. If you are unable to locate it, disconnect the entire radio... All of the plugs will only fit in there specified sockets, so do not worry about mixing them up. This should allow you to look more thoroughly back there. I hope this helps!
-Joe
test light? probe tester? how are you hookin up a radio with out a tester? did you just buy a harness? and hooked it up like that? did you try to see if both the ACC and IGN+ wires have power to them? if its an aftermarket headunit, most of them have a fuse behind it on the radio itself or the harness, but if your saying you stock radio doesnt go on either, i believe the radio fuse is either behind the drivers kick panel or pass kick panel.
well both aftermarket and stock radio doesnt work. The aftermarket radio was working then it just shut off in the middle of the song. Thats when i took the aftermarket radio out and replaced it with the stock and its still isnt powering up. So ur saying it could be the radio fuse?
