View Poll Results: Who has wheel shake?
no wheel shake with oem wheels
32
19.28%
no wheel shake with aftermaket wheels
19
11.45%
47
28.31%
wheel shake with aftermarket wheels
68
40.96%
Voters: 166. You may not vote on this poll
Who has it??? Wheel shake that is!
Old 04-26-08, 04:55 PM
  #31
GS FONZy
GS FONZy's Avatar
Originally Posted by sleeper408
I wonder if adding hubcentric rings to my stock 07' GS wheels could help absorb some of the vibration.
did the hud sice change on 06 and up GS's? What's the oem wheels bore size now?
Old 04-26-08, 06:58 PM
  #32
CBRA928
CBRA928's Avatar
so i have had my car since december, yesterday i got all 4 wheels/tires balanced and the problem went away.... woooohoooo hopefully thats it
Old 04-26-08, 07:14 PM
  #33
mellofelow
mellofelow's Avatar
Ummm... I have to change my vote from 'shake with aft mkt wheels' to 'NO shake with aft mkt wheels'.
Like CBRA928, I went to a good tire shop and had them balance the wheels to a 'T'... followed by a very thorough 4 wheel alignment. The computer printout results are very tight.
The shake & Shimmy at high speed is GONE!!!
Old 04-26-08, 09:40 PM
  #34
sleeper408
sleeper408's Avatar
I don't think it's changed. I was wondering if adding them would make a notable difference.
Old 05-15-08, 05:56 AM
  #35
3UZFTE
3UZFTE's Avatar
Do you guys ever drive over 90 mph? Let us know in a few thousand miles if the result is still the same. I have balanced my wheels to the 't', and dotted all i's.
Old 05-15-08, 06:19 AM
  #36
sojah
sojah's Avatar
i have been know to drive a little over 90 before. my shiz is currently steady, smooth, and feels very dialed in (almost glued to the road if you will, in a good way) at speeds from around 85-110, i try not to drive much over 110 for fear of having to react to a situation that might have an unfavorable outcome at such a high rate of speed.
had the shimmy, got pissed, fixed it, and now life is good again...
Old 05-15-08, 06:43 AM
  #37
dave11428
dave11428's Avatar
No shakeing after balancing and wheel alignment from a professional tire shop.
Old 05-15-08, 08:49 AM
  #38
Mike813
Mike813's Avatar
no shake after doing the steering rack adjustment, not noticeable at all anymore.
Old 05-15-08, 10:11 AM
  #39
CBRA928
CBRA928's Avatar
upto 140 its smooth, didnt go any faster then that
Old 05-15-08, 10:12 AM
  #40
CBRA928
CBRA928's Avatar
.... ohh its been about 500 or 600 miles since i got it fixed. ill check back in about 1000 miles
Old 05-15-08, 10:43 AM
  #41
SHiZNiLTi
SHiZNiLTi's Avatar
I have it at 62-67mph.
I also have it when braking sometimes, but thats probably from warped rotors right?
After I get my new 20" wheels what you advise that I do?
Old 05-15-08, 05:33 PM
  #42
Mike813
Mike813's Avatar
tighten the steering rack bolt by a few degrees.
Old 05-15-08, 07:27 PM
  #43
GSkid
GSkid's Avatar
i never had it until i put on my 18's, and now it still shakes when i go back to my stocks for winter.
Old 06-09-08, 06:48 PM
  #44
Mike813
Mike813's Avatar
use this as a check off list, i did all the above and my vibrations is pretty much all gone. oem 16's with everything original parts.
1.balljoints, check for play.
2.brake caliper stuck/warped rotors check
3.control arm check.
4.Correct sized hub rings for aftermarket wheels.
5.steering tension adjustment.
6.proper inflation
7.road force balance/alignment/balance/tire rotation
8.check for bent/damaged rims
9.check if tire is slipping off rim. chrome wheels has this issue alot (mark with crayon)
10.torque lugnuts to 76 ft.lbs (get a click/dial type torque wrench)
11.use proper lugnuts! titanium lugnuts could be a culprit.
anymore im missing?
Old 06-10-08, 06:45 PM
  #45
Och
Och's Avatar
Ever since I put on 16's, no more wheel shake.
Quick Reply: Who has it??? Wheel shake that is!
