water leak passenger side
Old 04-21-08, 01:28 PM
blkvader
blkvader's Avatar
Default water leak passenger side
my carpet has been damped for a while now, the back seat behind the passenger and the passenger also, i have read some of the threads and i though it was the sunroof or a bad rubber piece, after taking all the carpet out and taking the bottom cover under the glove compartment i discover that the hose for the ac drain was not completly seal, so the water was going thrue the black rubber mat to the passenger and rear floor carpet, hopefully this is helpfull to any of you out there.
Old 04-21-08, 01:31 PM
blkvader
blkvader's Avatar
Default more pictures
more pictures
Old 04-21-08, 02:45 PM
LS_FosHO
LS_FosHO's Avatar
wow excellent find, thanks for the heads up.!
Old 04-21-08, 04:27 PM
NBart
NBart's Avatar
If you hadn't noticed that it was leaking from there, I would have told you. Sucks when that happens.
Old 04-22-08, 09:41 AM
rra640
rra640's Avatar
Where is the leak coming from?? I just can't tell from the pictures.
Old 04-22-08, 03:17 PM
sck_GS300
sck_GS300's Avatar
LOL MAN I THINK YOU MIGHT HAVE THE SAME PROBLEM AS ME. I NOTICED IN MY CAR THE SAME THING, SO WHEN I GOT TO WORK I HAD A LEXUS TECH CHECK IT OUT AND HE TOLD ME THAT THE EVAPORATER BOX IS CRACKED AND LEAKING WATER INTO THE CAR, AND MAN IS THIS PART EXPENSIVE. A QUICK AND CHEAP FIX WOULD BE TO TAKE OUT THE EVAP BOX AND SEAL IT WITH SILICONE.THE EVAP ALONE IS $2000. HEY IF ANYTHING EMAIL ME AT POKER240@YAHOO.COM ILL BE GLAD TO HELP YOU OUT. MY NAME IS ALEX BY THE WAY
Old 04-22-08, 03:19 PM
tofu_house
tofu_house's Avatar
This is happening to my GS430 also.
I wonder if there is a DIY fix? Shed some light anyone?
Old 04-23-08, 02:10 PM
sck_GS300
sck_GS300's Avatar
A Quick And Cheap Fix Would Be To Take Out The Evap Box And Seal It With Silicone. The Only Problem Is To Get To The Evap Box, You Need To Remove Your Dash Goodluck!
Old 04-23-08, 02:21 PM
cxp2001
cxp2001's Avatar
Same problem here on the drivers side. Does anyone have pictures of the evap box exposed, Out of the car or with the dash taken off, exposing the evap box? I don't know how long it would take to remove the dash.
Thanks,
Old 08-24-14, 06:52 AM
freshmoney
freshmoney's Avatar
Originally Posted by blkvader
more pictures
Just bought my 99 Gs300.... carpet has be soaked for the past few weeks... thought it was the heavy downpours and a leak. I seen this post after checking every thing. Bingo found my leak. Thanks blkvander you saved me a headache
Old 08-25-14, 12:35 PM
Alphaman19
Alphaman19's Avatar
The sunroof can also leak. The plastic around mine had developed a small hairline crack. Went nuts for a few days checking the drainage tubes etc til I actually looked at the sunroof itself. A dap of caulk/sealant did the trick.
Old 09-13-21, 08:05 AM
robertito
robertito's Avatar
FYI— I had the dreaded leak a couple of years ago. Being a condo dweller and not having the capability to even diagnose the issue, I took it to the dealer. They disassembled the interior, fixed the issue, and charged $850 for the pleasure (after -15% coupon).
Earlier this year, another forum (non-car) that I frequent was having an auto insurance conversation, and comprehensive coverage came up. And I thought that this might fall under that category.
So I contacted my agent, who said send in the receipt. Two weeks later the bucks were ACH’d, no questions asked.
draco
11-19-23 04:40 PM
Tantrix
08-10-16 04:47 PM
4eign
04-26-11 03:17 AM
Toyboy300
06-03-10 09:23 AM
Benjune
Maintenance
01-21-10 08:54 PM
Quick Reply: water leak passenger side
