HELP! I got a crack in my "Y" pipe!
Old 04-29-08, 11:18 AM
VipDout
19x11.5 -51
VipDout's Avatar
Originally Posted by Rock-a-Lex
OK...I think I understand but still kind of confused on a couple of items. I just got off the phone with Luis @ Carson Toyota/Lexus and he indicated that NO cat-back exhaust system for the GS4XX is truly from the cats back. It's more like from the mid-pipe back because it will not replace the stock Y-pipe section coming off of the two cats up front.
So this notion leaves me with three options...
1. Buy a new Y-pipe from Carson Toyota/Lexus for $330.
2. Buy a used Y-pipe from a CL member.
3. Go completely custom like you did.
What should I do? Where did you install the o2 sensors and how? Did you stay with the same 2.25" diameter piping? Where is your resonator? Could you PM me where you got your X-pipe from and other piping? I would keep my Borlas with this scenario (instead of buying the Magnaflows).
How does it feel BTW? Launching...Highway pulls etc. etc. Please PM me if you don't want to discuss on this thread. Your help is greatly appreciated!
Sorry for the in detailed wording .. at work
I had the body shop delete my resignators .. and the o2 sensors weren't touched , same location from what remember ? or have them add it.. in the same location
We hacked off all the piping from the cat converter back .. and the shop actually made a custom X-pipe . took them 30 mins and it was Nice ! vs buying one from online and waiting .. .and 2.25 inch piping with mandreral bends to the exhaust .
It was all fabricated in front on me .. literally front the top of cat all the way back .
I only repeat only have that done to the motor was the exhaust ..
.. look up one of my movies on youtube ... "pxrlex" in the search portion ...
and I think it has me reving my motor ..
you can use your borlas like I used my magnaflows .. and you wont have any problems ..
Cheers and good luck .. Cant hurt to upgrade right ? btw the X-pipe sounds nice ..
Ohh sorry didn't read the bottom portion ..
When I got the exhaust put on .. It sounds great .. It has over all enhanced performance .. but I can not give you a number unless you buy me dyno time hehe
My mid to top RMP has alot more pull alot.... vs stock going through gears ..
lower rpm no gain I believe
Old 04-29-08, 12:11 PM
Rock-a-Lex
Rock-a-Lex's Avatar
Thanks man...now I have to find a damn shop to do all this. Would/could just any old Midas or Meineke handle this custom job?
Old 04-29-08, 12:39 PM
UncleRay
UncleRay's Avatar
Is it the Y pipe with the O2 sensors are connected? If so, welding it is totally out of the question. I had mine welded, and it POPPED right out. Just get a custom one
Old 05-09-08, 01:49 PM
GILLEXUS
GILLEXUS's Avatar
Rock-a-Lex
what did yu end up doing? I would think if you went custom, the would just put a bung in your front pipe for your O2 sensors. I take it it was the ront pipe that cracked.
Attached Thumbnails HELP!  I got a crack in my "Y" pipe!-gs430-exhaust-systemfront.jpg
Old 05-09-08, 01:53 PM
carbongs
carbongs's Avatar
go toyomoto headers and y pipe then custom pipe all the way lol. might as well if you are lookin at 700. my whole set up was like $600 if i had to pay for it.
https://www.clublexus.com/forums/sho...rbongs+exhaust
frankf2014
05-15-17 09:05 PM
bigwes
Performance & Maintenance
08-30-12 11:13 AM
ISFROMHELL
Performance
22
03-23-12 08:50 PM
Spyder187
06-25-05 12:56 PM
carmcanc
05-02-05 11:10 PM
Quick Reply: HELP! I got a crack in my "Y" pipe!
