My rpm was around 3500 rpm at 80 mph on gear 5, is that normal ?
Old 04-28-08, 01:58 PM
masboy
masboy's Avatar
Default My rpm was around 3500 rpm at 80 mph on gear 5, is that normal ?
i've been noticing these days my rpm is around 3500 while i was at around 80mph on gear 5, is that normal ? and when i tried to hit 85-90mph....the rpm went higher and higher.....
Old 04-28-08, 05:55 PM
CBRA928
CBRA928's Avatar
i think for a gs300 normal is 3000 at 80mph, at least thats what mine is and i thought that was high when i first got it, but did a little searchng and found out its normal
Old 04-28-08, 07:02 PM
kevs98GS4
kevs98GS4's Avatar
it's normal because of the 3.92 rear end your guys have in the gs3. i upgraded to the 3.76 and I also run 3000 at 80
Old 04-28-08, 08:36 PM
4ntvings
4ntvings's Avatar
for some reason, i thought u had the v8! bad memory
i think mine is the same. if you want, we can run on the fwy and check the rpm's
Old 04-29-08, 12:53 AM
tommyjaix
tommyjaix's Avatar
yeah our cars are high revvers =(
its about 2.4k rpm @ 60mph and its exactly 3k rpm at 75-78mph
Old 04-29-08, 03:40 AM
Mike813
Mike813's Avatar
if i remember reading JDI racing's thread about the VVT-I system in our vehicles, they can give us a low rev but yet create the same powerband as a higher reving vehicle for emissions and increase fuel economy? correct me if im wrong. but heres the link https://www.clublexus.com/forums/sho...d.php?t=114233
Old 04-29-08, 05:04 AM
gs-ireland
gs-ireland's Avatar
Was the gearbox cold?
I noticed if my gearbox is cold the lock-up on the torque converter does not work and will rev at 3500 @80mph. With the gearbox warm the lock-up is fine and ticks over at 2,900 @80mph
Old 04-29-08, 06:15 AM
sinistervr
sinistervr's Avatar
im at 3000~3100 @ 80mph..tire size will also affect your rpm to speed
Old 04-29-08, 04:33 PM
masboy
masboy's Avatar
thanks for the reply folks! im glad it's normal....i just a little bit hesitate to go to 90mph w/ the rev sound
Old 04-29-08, 04:44 PM
chuckb
chuckb's Avatar
3600 rpm
Old 04-29-08, 04:49 PM
masboy
masboy's Avatar
thanks a lot chuckb !! =D
thats a low mileage btw.......similar w/ 4ntvings
Old 04-29-08, 05:06 PM
VipDout
19x11.5 -51
VipDout's Avatar
he has a gs430 ... also ... hella low miles .. omg ... do you even drive yours ??
Old 04-29-08, 05:16 PM
chuckb
chuckb's Avatar
that was 1 year and 9 months ago, I have 45,2xx miles now.
Old 04-29-08, 05:20 PM
VipDout
19x11.5 -51
VipDout's Avatar
haha still pretty low....
I have 100K more than you
Old 04-29-08, 07:17 PM
Jayd41
Jayd41's Avatar
You think that's bad, my RX-8 is at 4,000 rpms at 80 mph.... and that's in 6th gear!
Quick Reply: My rpm was around 3500 rpm at 80 mph on gear 5, is that normal ?
