HELP! Amsoil Synthetic Fluids
ok.. i'm going to be power flushing and refilling all of my fluids. i have a 2000 gs400. which fluids am i able to swap out for amsoil? and if you'd be so kind as to help direct me to a website where i can order it and item/part numbers for the fluids? thanks in advance! ^_^
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
You typically just pick it up from a local distibutor vs ordering on the web... they're everywhere. https://www.amsoil.com/dealerlocatorresults/
I use Amsoil Synthetic ATF in my transmission, but other brand stuff (Redline LSD, Mobil One oil, etc) elsewhere in the car.
i just plan on doing an entire system power flush and refill to all synthetics.
differential
power steering
brake fluid
oil
transmission
is there anything i'm missing? what brands do you recommend? and how much do i need for it?
differential
power steering
brake fluid
oil
transmission
Super Moderator
For brake fluid, I'd actually go with ATE Superblue, but the rest of them you can go Amsoil with. For power steering, Amsoil ATF will work perfectly, but I like Mobil 1 ATF.
Lummie2IS
04-01-14 11:38 AM
