Jacked up the front and was able to move my front wheels a bit side to side. i know its from the upper control arm area but im just wondering if have replace the whole control arm or can i just replace the bushings? how can i tell?
Lexus doesn't sell OEM bushings separately. However, you can buy an aftermarket polyurethane set from Daizen that includes bushings for the upper, lower, and caster arm.
I had play also in the front, so my mechanic had to replace the control arms...I guess if you plan on doing bushings it may be a good idea to do it all at once. If your asking if you can do bushings instead of I don't know for sure..Hope that helps
