What a difference cleaning the MAF and air filter makes...
#31
Here's a link to a great write up with pictures and diagrams from SeattleGS400.
https://www.clublexus.com/forums/sho...d.php?t=345147
#32
Thank you very much, sir! ! !
#33
After reading this I immediately went out to the garage and
clean the MAF sensor and throttle body with CRC products made specifically for each item.
I noticed a huge difference in acceleration and my idle is not as rough no more.
Great info guys, I wish i did this sooner with these crazy gas prices.
#35
I was cleaning my MAF today (so easy) and was wondering what this part on the side of the assembly is. One side is very dirty (side facing air flow) and the other side is relatively clean. What is this part? Can I clean it with the MAF cleaner?
#39
You have to do it in good light but on the 300 you can see the little wires if you look down the holes on either side of the plastic assembly. I sprayed up into the hole where I saw the wires. I wanted to clean the part I referenced above as it was quite dirty, but figured I would ask first. The part looks like a used match and is along side the small black tube.
#43
#44
