Stock HID replacement question.
I have 98 gs4 with stock HID, and I need to replace it. Can I buy aftermarket HID kit to replace it? Or I have to buy only stock kit(ballasts, bulbs etc)?
Well the thing is I need new ballasts as well, so let's say I'll buy HID kit from ebay with D2R bulbs, will they fit/work correctly as stock system?
I found aftermarket D2R kit for about 160 shipped. So if it's D2R will I have any problems with installing and operation of HIDs?
Location: ~SIMPLY TUCKED~ scraping the mean streets of L.A.
if the HID kit is a D2R/D2S kit then it would work with your car. the ballast would fit under the headlights like the OEM ones, so you would have to mount it somewhere else like the post stated above ^^
just make sure you a quality HID kit, they're a lot of them out there and the cheap ones don't last that long. i hope this helps answers all your questions.
-john
-john
xenonking.com has color tempatures 3000k-10000k, and if you type in coupon code "xkgoog" itll give you 20% off. VisionPro kits (like mine) will be 179 shipped with the discount, and McCulloch kits will be ~199 shipped with the discount.
