Am I the worlds FIRST E85 powered Lexus, or just on CL?
I asked here before if anybody used E85 on a GS3, but mods moved it to Car-Chat!
E85 has a higher octane rating than ordinary petrol, but less BTU's. That is why the economy is ~ 20% less than petrol. So, if E85 is ~30% cheaper than petrol prices you are on a winner!
The 2 main probs for E85 is it is corrosive to older silicone seals, not much of a problem with newer cars, but I am unsure about the 2GS. The second problem is due to the E85 having lower BTU's, it needs more fuel-per-bang, so there are kits out there to keep your injectors open a little longer:
http://www.flextek.com
Does anybody know if our fuel lines/pumps are ok with E85?
you basically have to have a over powered fuel set up.. what i mean is if your turbo lets just say you need 1 walbro 255 to support 400 whp, now with e85 you would need 2 walbro 255s plus bigger injectors etc..because you need to add like 30% more fuel..its not hard if you have standalone, but if your on a factory ecu its a pita
Jeff, its funny you said this "Car mechanics seeing more problems caused by ethanol gas" http://gmy.news.yahoo.com/v/8005145
CEO
CEO
E85 is a different animal. It's mostly alcohol so it burns much cleaner and leaves nearly no residue. Gasoline on the other hand leaves behind a ton of soot and carbon buildup. And as a few of the other people have mentioned here. Ethanol is less energy dense compared to gasoline at the same volume. You do need ~25% more of it to produce proper combustion in the engine. Thing is that with a boosted engine and the mandatory extra fuel being packed in per cycle. It actually ends up producing more power per stroke than gasoline.
Jeff, are you still running standard rubber in your fuel system? I know people say that its not an issue in newer cars but it is. Its not okay, its just okay at the moment. Just because the rubber is newer doesnt keep it from breaking down over time. From what I understand is unless you switch your fuel system to a silicone material I fear you may have problems down the road. I was researching doing an E85 swap when I read that article I mentioned about 4 years ago but when you factor in the extra money you put into swapping the fuel system parts, extra fuel needed to burn (more fill ups), and (at that time) lack of fill stations in my area it was seemed better for me to just buy the race fuel for the track and run 93 on the street. Im not knocking what you did at all. Just wondering if you swapped anything over from standard rubber. Your moving forward and bringing your GS into the future with you. I respect that.
I've upgraded my whole fuel system not with ethanol in mind, but just due to the fact that I need so much fuel in the system lol. So when I built it, everything was overbuilt and I guess that paid off. The rubber O-rings have all been replaced with Viton rings since a while back. The fuel lines are the stainless braided nitrile AN-6 racing kind. The material the hose is made of is compatible with methanol and nitromethane both of which are WAAAY worse than ethanol will ever be. Only time will tell how this setup hold up. I'll keep you guys updated
Only downside is that the Walbro fuel pump I am running is not rated for ethanol. However, there are numerous Subaru people that have converted to E85 for several years now with no problems at all. They are even using the stock fuel system(lines, rings, injectors), but with just the upgraded Walbro fuel pump. There are a ton of Subies that have put 20-30-40k and counting running exclusively on E85.
Thats awesome that once you build a "race" fuel system with appropriate lines it can handle whatever fuel you throw at it. It makes things much easier in the long run when you build it right from the start. Good job Jeff. Your car has become a complete animal in such a short time. Keep it up.
CEO
CEO
^ and bigger injectors.
Half of the reason why people switch to e85 is because of the octane benefits, and the other half is price. For a regular car I don't really see the benefit of going e85 at all. The bioenergy required to make the same amount of energy that the fuel provides is far greater than its benefits.
We dont' have much e85 stations in cali, but we are big fans of water/meth injection.
You might be the first one, but I think there's a sc300 somewhere that did this.
