Squeaking steering column? Here's my $3 solution
Old 07-22-08, 01:12 AM
ISFjimmy
ISFjimmy's Avatar
Originally Posted by Coco-bun
I'm just writing this up b/c when your date complains about how bad your steering squeaks every time you put in/take out your key
if she dont like it, she can walk. lol.
Old 12-04-09, 07:46 AM
sakataj
sakataj's Avatar
coco, im headed to autozone to pick up some white lithium grease but im not having the same squeaking as you'll were. mine happens when i turn the steering wheel hard/left to right.will update if this fixes mine
UPDATE....no need to go to autozone. we have the ags brand white lithuim grease in stock. soon as i get off here im gonna go do this
Old 12-04-09, 08:33 AM
Sash1mi
Sash1mi's Avatar
I need this for sure........ also guys, can this grease also be used on the seat rails? Can I use the white lithium grease too on the seat or no?
My seat squeaks bad like a fat kid farting eating cake at the same time. =/
Dara
Old 12-04-09, 08:44 AM
timgs300
timgs300's Avatar
Dara
You can definitely use for seat tracks, etc. You should also check for loose track or wear (alot of play) cuz the seat takes a lot more punishment than the steering wheel.
Old 12-04-09, 09:14 AM
Sash1mi
Sash1mi's Avatar
Sweet... thanks for the reply!!
Dara
Old 12-04-09, 09:41 AM
GS4_Fiend
GS4_Fiend's Avatar
Very helpful thread thanks for sharing
Old 12-04-09, 01:21 PM
CPMD
CPMD's Avatar
Just a hint, to remove the bottom panel, you have to manipulate the joystick steering wheel controller, i.e. have the steering wheel out the most, and then get the bottom panel out
Old 12-05-09, 06:34 AM
wbmx1981
wbmx1981's Avatar
Thanks for the write up. My steering wheel was stuck in the upward position. I used WD 40 for now and it worked great. All I hear is normal motor sound no sqeaking or grinding.
Old 12-08-09, 01:31 PM
sakataj
sakataj's Avatar
lol i know, i figured that out when i went to do this. i was like wtf lol.
OP.....now i didnt think this would fix mine. im going to the shop tonight and breaking out the trust T30 torque and taking off the steering wheel. i think my clock spring is making my squeak. will find out and update l8r, im hoping lol
Old 12-08-09, 04:08 PM
CPMD
CPMD's Avatar
Lol that's probably the most trickiest part in this whole thing, trying to get that damn lower piece off haha.
Old 12-08-09, 05:37 PM
chigguh
chigguh's Avatar
thanks! i was getting tired of the squeeking..
Old 01-14-15, 09:00 AM
berge
berge's Avatar
Default Squeaky sc430 steering wheel
I'm just writing this up b/c when your date complains about how bad your steering squeaks every time you put in/take out your key, it's bad. I couldn't find a DIY so I did it myself and thought i'd contribute since our cars are getting 10 years old.
Please fix your car at your own risk!
1. go get some general purpose grease from Autozone or wherever. I got a big can for $3 and it says it's used by many Japanese cars...so I figured,
2. take off the 3 bolts thats holding the steering column cover. If you don't know where it's located or how to, just looking around the steering column. two are behind the steering wheel and you will have to turn it to get to it. Lightly take apart the bottom and top cover.
3. start greasing!!
and I recommend some plastic gloves also (like those 100pack for 5bucks one).
the red circle is one of the culprits
close up. grease around it.
Now, get underneath your steering column...and you should see this.
see that small metal part in the middle of the pic?
here's the close up of that middle metal part. grease where it's circled red.
real close up
Now, you're gonna have to "pack" the grease and tilt up/down as you grease to get the grease around that shaft. Do so until the sound goes away.
the finished product, tada
Thanks for the useful help. I will try and let you know if it worked.
Berge
Old 01-15-15, 09:31 PM
sam12345
sam12345's Avatar
Just don't use stinky grease or you will be smelling it forever
Old 01-15-15, 10:56 PM
johhntran
johhntran's Avatar
thank god someone bumped this back up, its been getting annoying and i had no idea on where to start!
Old 03-30-15, 07:31 PM
Rentzer
Rentzer's Avatar
Default Great advice which cured my problem
Only one thing to ad.
Make sure the top cover is removed first and put back on last.
Top and bottom snap together.
Steering wheel squeak done.
10 minutes getting the bottom cover off.
(It would not clear the square tilt button.
Stumbled on the solution which was to remove the top cover first, to give more room to maneuver off the bottom cover.)
Greasing took 5 minutes, mostly spent raising and lowering the steering wheel to make sure the grease covered the worm gear and both ends of the shaft.
15 minutes attempting to get the top cover and bottom cover to align.
(Finally figured out that although it was easy to place bottom shaft cover around square tilt button without having top cover on, with the bottom cove in place the top cover metal brackets with the holes to allow the screws to go through and into the plastic screw receiving shafts were hitting those shafts. So top cover needed to be fitted down first. After that it was easy to raise the bottom cover into place to meet the top cover.
Article was great for photos and solution.
Just follow sequence as above.
Now squeak is gone and I need not set any mouse traps.
Bob
Quick Reply: Squeaking steering column? Here's my $3 solution
