can you guys explain fender pulling and rolling or shaveing
iModerate
Be very careful with a roller, it's easy to warp the outside fender. Since the clip holes create a different tension when the roller is on that spot.
thanks!
i'd venture to stay away from the roller just because there are more chances to warp, chip, bend, and crack the fenders/paint. i did a very mild pull on my front fender. that is exactly as it sounds. heat up the fender a little bit and pull a little bit. i hope my writeup helps you with shaving. it is very easy. just be careful
Shaving the fronts will weaken the structure and since you will be turnin your wheels, it will rub against your fender and might cause some easy damages... Of course, depending on how low you are...this is just from what my friends told me when I was thinkin of shaving..
