GS400 rough idle WITH AC on
my car started feeling weird this past week, where the car would idle fine without the AC on, but with the AC, the car idles pretty rough. any ideas?
i've tried cleaning the throttle body, seafoaming (lots of smoke), cleaned my maf, air filter, seafoam in the gas and crank, and reset the ecu. and yes, new ngk iridium ix plugs were put in last month.
thanks,
GSquicksilver
thanks,
GSquicksilver
yea, i'm still on the original mounts. my ac compressor is fine and does not have any odd noises.
if you don't mind me asking, where did you get your mounts replaced and how much does the job cost? thanks.
i'm getting mine replaced , it'll probally run from 600 -1000 dollars for all mounts including tranny. $1000 wasn't even a dealer quote.
Our cars only have 3 mounts: (2) engine mounts and (1) transmission mount. The engine mounts are $100 each and the transmission mount is $70. Just get the shop to do the engine mount. You can do the transmission mount at home in about 15 minutes. It's very easy.
The engine mounts should only take about 2-3 hours to install.
GSquicksilver, where in CA are you? I can refer you to a shop that can do your mounts for a good price.
I'm in the OC too. If you have time, check out this place:
Vinam Auto Repair
15052 Jackson St.
Midway City, CA 92655
Take a look at this thread:
https://www.clublexus.com/forums/sho...ighlight=vinam
Vinam Auto Repair
15052 Jackson St.
Vinam Auto Repair
15052 Jackson St.
Vinam Auto Repair
15052 Jackson St.
