Any guides on removing the steering wheel?
Old 06-09-08, 08:03 PM
Grip
Grip's Avatar
Default Any guides on removing the steering wheel?
Are there any guides on how to properly remove the airbag, steering wheel, and re-install it?
Or is it pretty straight forward.
I am pretty mechanically inclined.
Old 06-09-08, 09:20 PM
corkycal
corkycal's Avatar
don't do it because the air bag can blow up on you. take it to a person who has done it or know what they're doing.
Old 06-09-08, 10:22 PM
lexusondubs
dubsonlexus
lexusondubs's Avatar
thats funny i removed mine and reinstalled without it blowing up ..its been a while but from memory there was 2 or 3 small bolts that hold in the airbag on the side of the steering wheel then once that is removed there is 1 large nut holding the wheel in place once you get the bag off the rest is self explanitory
Old 06-09-08, 10:37 PM
GS_OREO
GS_OREO's Avatar
Disconnect the battery and let it sit for a few mins so the remaining energy could discharge.
Align the steering wheel straight.
Then tear into that badboy
Old 06-10-08, 05:16 AM
Grip
Grip's Avatar
How do you remove the cover? Just pry it off?
Old 06-10-08, 08:19 AM
rra640
rra640's Avatar
the cover over the airbag??? DON'T do that!!! The airbag comes off in once piece as one unit. I believe you will see the screw covers on the sice of the bag assembly.
Old 06-10-08, 08:42 AM
Grip
Grip's Avatar
The steering wheel cover with the Lexus "L" on it.
Old 06-10-08, 05:02 PM
phillygs3
phillygs3's Avatar
Your deffinately gonna need a puller . If you look on both sides of the steering wheel one side has a small knockout plate and the other side has one also about the size of credit card maybe a lil smaller behind them are torque screws when you loosen them the air bag should come off just disconnect the wire harness. make sure your battery is disconected
but your gonna need a steering wheel puller I bought one from autozone for about 8 dollars deffinately worth it.
Old 06-10-08, 05:34 PM
lexusondubs
dubsonlexus
i didnt need the puller ?? why would he need one ??
Old 06-10-08, 05:37 PM
GS FONZy
GS FONZy's Avatar
Originally Posted by lexusondubs
thats funny i removed mine and reinstalled without it blowing up.
I have heard that so many times, it should be send to Myth Busters.
Kinda like the Donky Show, only a friend of a friend who's friend knows a guy that's realated to the guy that has seen it
Batmobile
10-27-22 01:57 PM
badx33
11-11-09 10:04 AM
Zagman91
01-17-09 02:30 PM
lexus188
01-20-08 10:54 AM
DRFJB
SC- 1st Gen (1992-2000)
06-08-05 10:40 PM
Quick Reply: Any guides on removing the steering wheel?
