where can i order a replacement key
i guess lexusparts is no more, i need a whole new key for my '04 GS430. if i recall correctly, a replacement key was about $150. i'm not going to the dealer since they're going to rip me off anyways - where can i order it online?
http://www.l-tunedparts.com/ but i'm pretty sure you need to go threw a dealership in order to purchase one
If u just need the key and not the chip, then u can go to any good looksmith and they should be able to cut one for about $30 - $40. If u need the whole setup - key with the chip programmed u will have to get it from a lexus dealer. will prob run u around 150
http://www.sewellpartsonline.com/par...l.asp?id=68697
You can just get the key and program it urself.. the only key that doesn't come with a chip is the wallet key.. as long as you have the master key you can program any other key yourself, if you don't have the master key you'd better have that metal number tag with the key code on it, if not.. well I think you know what I'm going to say...
You will need to go throught the dealer to get the key cut and programmed. $150 seems right for the key, but then you will be charged for the labor to program. Let us know how much it cost and which dealer you wind up using.
If you can manage to get yourself a sub key here's do it yourself key programming: http://www.automotiveforums.com/vbulletin/t371582.html
programming the key yourself will save you 50 bucks
excluesive
12-30-07 07:36 AM
2007, 350, club, extra, instruction, key, lexus, lx470, miami, order, program, repacement, repalcement, replacement, rx, send, spare, step, wallet
