fog light hid problems :(
well i just got my hids in today. i installed the hids for the headlights. BUENO!
i installed the ones for the fog lights NO BUENO
its just a simple plug and play kit! is there any kind of fuse i need to change out to make these work. i know i connected the plugs to the correct places!
any help please!!! i want to see my hids in action before night hits!!! thanks guys!
If the culprit isn't a blown fuse, try this...
First, make sure all your connections are solid. Second, try turning around your factory connector that plugs into the HID ballast.
Are you using ORACLE brand?
Same thing here. The resting current draw is around 4 amps per ballast, but as much as 14-18amps at start up/ignition. Drivers side kick panel is where you'll find it
