60mph Vibrations - DIY Steering Tensioner Adjustment
Old 06-20-08, 07:02 PM
PR FIEBRU
PR FIEBRU's Avatar
Post 60mph Vibrations - DIY Steering Tensioner Adjustment
I know this has been posted on other threads before. The difference in this one is that its on the first page.
Today I did the steering tensioner adjustment. I have not yet tested out the car. Ill post tomorrow if it really worked
1: go to your local hardware and get a 5/8 x2 bolt and nut.
as you can see the tread is smashed. I did that so that the nut does not spin out of place.
2: Mark the position of the tensioner
3: Use a flat head screw driver and a hammer to take out the the nut that secures the tensioner in place. Hit it on an angle untill it comes out. Use w40 and be patient.
3: Once you loosen the exterior nut then tighten the main bolt 1/8 turn clock wise. Adjust nut that secures the tensioner and you are done.
I hope this helps the vibrations. Ill post tomorrow.
total cost .... 60cents for bolt 20cents for nut = 80 cents. Nice....
n1ck (11-19-18)
Old 06-20-08, 07:22 PM
Och
Och's Avatar
Thanks for the tutorial. I was actually able to solve my vibration problems completely by switching to 16" rims, the car glides down the road smooth as silk. It was vibrating with the old 17's, but interestingly enough, right now I have these 17's on my LS, and there are no vibration whatsoever, none, smooth as silk. I think 2GS steering rack just sucks and is too prone to vibrations.
One thing I do not understand from your tutorial, why did you smash that nut like that? Your turning that pretension nut clockwise, right? And to tighten the nut on that bolt, you would also be turning it clockwise, right? So how would it come out?
Old 06-20-08, 07:27 PM
Solo_D33A
Solo_D33A's Avatar
Great post! Just what I need!
Old 06-20-08, 07:31 PM
JeffTsai
JeffTsai's Avatar
He probably did it so incase he turned it too much, then he can go back
Old 06-20-08, 07:32 PM
Och
Och's Avatar
That is true too, lol.
Old 06-20-08, 07:37 PM
PR FIEBRU
PR FIEBRU's Avatar
I did that so that the socket can reach the nut. The socket that I had was not deep enough. So instead of buying a deep socket I improvise.
Yep also to turn back the tensioner. Now it works both ways
Old 06-20-08, 07:40 PM
Och
Och's Avatar
Ok, so you banged the thread on below and above the nut? I kind of see that now.
Old 06-20-08, 08:31 PM
rudesgeiger
rudesgeiger's Avatar
Will this work on the 2000 Lexus GS400 as well?
jack
Old 06-20-08, 08:33 PM
mellofelow
mellofelow's Avatar
Awesome!!! Can't you use 2 nuts locked against each other?
Old 06-20-08, 10:44 PM
pitmanr200
pitmanr200's Avatar
how do you know how much to turn and when its right
Old 06-21-08, 05:11 AM
gs-ireland
gs-ireland's Avatar
What it simply does is tightens up your rack so you can have the steering as hard or as easy to turn as you want. There is an exact torque setting, but it does not suit everybody's car or personal taste.
This mod is used here to get the pre-tensioner to absorb the vibrations before it travels up the steering shaft where you feel it.
With this you can have BMW effort to turn the wheel or as light as some small mico-cars, word of caution: if its too tight, your steering will not auto-center (when you let go of the wheel after a turn and it centers itself).
The best thing to do is tighten (clockwise) by 1/8 turn go for a test drive and repeat and repeat until you find your sweet spot.
PS for those living in metric lands, the bolt size is an M16
Old 06-21-08, 07:54 AM
PR FIEBRU
PR FIEBRU's Avatar
Great news! The 60mph vibrations are very slight now. Like gs-ireland stated you adjust a little at a time until you find the sweet spot.
Before I readjust, I will get the front tires high speed balanced.
Thanks to everyone prior to me that did this adjustment and gave me the ideas. There are a few threads on this forum that explained what I just did in a lot more detail. All I did was take that information and Do It Myself.
Old 06-21-08, 08:12 AM
Ay-nako
Stop the Copy!
Ay-nako's Avatar
wow man good job im definatly going to do this to my gs!
Old 06-21-08, 08:21 AM
vaki2
vaki2's Avatar
Thumbs up
Excellent write up.
Thanks
Old 06-22-08, 12:01 AM
kenkaniff
kenkaniff's Avatar
Can someone explain this step to me? I'm stupid.
Quick Reply: 60mph Vibrations - DIY Steering Tensioner Adjustment
