Rear light bulb dash sensor:
Old 06-24-08, 08:31 PM
-Future-
-Future-'s Avatar
Question Rear light bulb dash sensor:
My dash light for a rear bulb burn out has stayed on continously for two days! I checked all my rear lights and none seem to be out, even the reverse lights. I'm going to pull out each bulb individually and replace it and see if that helps. It started after I had my 90k service done by my local mechanic. Any thoughts??
Old 06-24-08, 08:51 PM
Solo_D33A
Solo_D33A's Avatar
did you get someone to brake for your and you check all the lights light up?
Old 06-24-08, 09:01 PM
Lamchop21
Lamchop21's Avatar
If that doesnt work, make sure all of the bulbs are in all the way. The bulbs will light up even if their not pushed in all the way. To check, just push it in with a little force. Hope that helps
Old 06-24-08, 09:33 PM
chrispy
chrispy's Avatar
Maybe one of the license plate bulbs? 3rd brake light?
Old 06-24-08, 10:11 PM
Spyder78
Spyder78's Avatar
license plate bulbs are not detectable but the 3rd brake light is.
Old 06-25-08, 06:01 AM
-Future-
-Future-'s Avatar
Yup. I had someone hit the brakes and everything looked good, I even checked the license plate bulbs just in case. Third brake light is good too, I'm going to take them out and push them all back in when I get home.
Thanks for your tips guys
Old 06-25-08, 06:20 AM
dwoods420
dwoods420's Avatar
Did you happen to put any LED bulbs in the brake lights?
LED's will trip that sensor
Old 06-25-08, 03:33 PM
fatkidGS3
fatkidGS3's Avatar
ive had this same problem on my car, but mine has been goin on for about a month, ive changed all the lights, checked to see if they were in all the way, and still no luck. the other day i got stuck in a driveway and had to "rock" the car and switch from reverse to drive many times and the light went away, Sweet!!! no not sweet, two days later it came back on and has been on since. Any ideas or help would be awesome....thanks in advance
Old 06-25-08, 06:03 PM
3UZFTE
3UZFTE's Avatar
Welcome fellow Minnesotan, and 2GS owner. I think the problem is in your lights, often the oouter tail lights will burn out leaving the indicator on and the drive will often not notice the light is burn out. I bought the vehicle with both outter rear tailights burned out, didn't notice until i completely pulled the lights out to clean them out... Notice both inner and outer tails will light up, but only the inners will light up upon braking... Does the indicator come on when you step on the brake, or when the lights are turned on..?
Old 06-25-08, 06:24 PM
-Future-
-Future-'s Avatar
Default I think I fixed mine!
Found out my problem, one of my wedge bulbs was a little loose. Another one of bulbs works but looks burnt out - burn marks on bulb itself. Well so far it stayed off, we shall see!! Thanks for your help.
Old 06-25-08, 07:15 PM
MTElnb1
MTElnb1's Avatar
I have the same problem. My light indicator only comes on when I turn on the lights. I've checked everything and can't find the problem.
Old 06-27-08, 07:22 AM
fatkidGS3
fatkidGS3's Avatar
it seems to only happen when i step on the brake after start up and shift into reverse, but ive checked and the reverse lights both work just fine, but thanks for the ideas, i guess ill go check all the bulbs again for lighting upon braking and shifting into gear.
Old 06-27-08, 10:00 AM
ISFjimmy
ISFjimmy's Avatar
just do what i did...
take off the light bulb of the dash, so that light cant come on
Old 06-27-08, 11:00 AM
-Future-
-Future-'s Avatar
My lights all lit up, but my bulb was loose in the socket. Look at all your sockets and make sure the bulb clicks in and is snug. Being loose is what tripped my sensor. GoOd luck!! That lil light was soOoOoo annoying!!
Old 06-27-08, 05:40 PM
fatkidGS3
fatkidGS3's Avatar
thanks future, ill try that let you know, god i hope this works, ur right that tiny little p.o.s. lite is there always telling me hey look here im not goin away
Quick Reply: Rear light bulb dash sensor:
