SAFC/// Fuel Controller time// MPG + // HP TQ +
The dyno was performed on GS42NV's car.
Here is the thread:
https://www.clublexus.com/forums/sho...ht=x-pipe+dyno
well i gots an appointment with the srt place this afternoon to get a baseline first and see if it can benefit from being tuned, which i thought it might but the dude says until you baseline it you can't just assume that it needs to be tuned. so this afternoon it shall be base lined then tuned if need be... sounds kinda fun...
plug and play huh....maybe after you solder twenty something wires with clips on each end. haha, all piggybacks are solder/tap into your ECU. There's still a minimum of tapping even you buy the specific harness for your car (i'm referring to Greddy Ultimate). Newer cars like our GS is on the lean side already from factory COMPARE TO say like the first "gen" SC. You might be able to squeeze some power gain out (assuming everything is factory) if you have a piggyback controller. If you want to save gas, just put an egg under your gas pedal and drive 60 everywhere you go... (just a suggestion, don't flame me)
You should save yourself the headache of getting an afc and having it dynoed, tuned etc.... SRT makes an intake that comes with a piggyback ecu pre-tuned for your car as well as a full intake, filter and heat shield. Do a search on the forum for SRT Intake, you will find it's one of the best bang for the buck mods and I think they are only $449. Another plus is SRT is in Maryland (Beltsville) so you can just go pick it up and or have it installed in one shot, takes them about an hour to install it, they also have an in-house dyno if you wanted to see the before and after results so you know for sure you got what you paid for.
Have them put the afr on the dyno sheet and in rpm not mph. It will be easier for a later comparison.
dlamb89
15
06-07-18 09:52 PM
Magellan55
HS 250h Model (2010-2012)
04-08-16 06:59 AM
