what a teaser
Old 07-06-08, 10:20 PM
tommyGS3
tommyGS3's Avatar
Default what a teaser
Old 07-06-08, 10:21 PM
tommyGS3
tommyGS3's Avatar
save for dyno sheet
Old 07-06-08, 10:30 PM
Seize
Loves Snickerdoodles!
Seize's Avatar
Ahhhhh...nice!!
Old 07-06-08, 10:36 PM
MrExecutiv
MrExecutiv's Avatar
nice......
Old 07-06-08, 10:51 PM
swat1727
swat1727's Avatar
i never knew how ppl deal with the vvti when putting on a turbo. how do u disable the vvti? non of the shops i asked do that.
Old 07-06-08, 11:02 PM
tommyGS3
tommyGS3's Avatar
hks wastegate and hks bov on order, still need to install RC 550cc injectors and aem fic. hoping i get all this squared away by the end of this month.... and still need to do my headgasket...what a long list.......
Old 07-06-08, 11:34 PM
JeffTsai
JeffTsai's Avatar
Tommy. nice setup you got going there. Seems like more and more boosted 300's showing up every day lol.
Why would you want to disable VVTi? It's great for low end to mid range power and helps spool up the turbo faster. It's only the shops that don't know how to work with it or tune it that hate it. Also, Brian Crower came out with cams for the 2JZ VVTi motor. So that fixes the problem of cams not being aggressive enough. It was a problem back when the only cams available for the VVTi motor was the stock set, but no longer is that an issue.
BUT, if you really want to disable VVTi it's very easy. Just unplug the connector going to the VVTi solenoid and it will stay at a fixed 0 degrees advance. Simple as that
Old 07-06-08, 11:42 PM
LS_FosHO
LS_FosHO's Avatar
oooohhh damn!!!!
Old 07-06-08, 11:55 PM
Fat Felix
Fat Felix's Avatar
the pipe leading into the throttle body looks super close to that turbo! Will that be a problem or is there a remedy in store for that?
Old 07-06-08, 11:59 PM
ElitistK
ElitistK's Avatar
^mine's closer.
heat wrap it and you won't have a problem.
get a turbo blanket asap. throttle wiring might be too close to the turbine. i melted my wiring by keeping them at the stock location.
Old 07-07-08, 10:14 AM
wowitztai
wowitztai's Avatar
nice man
Old 07-07-08, 10:55 AM
LEXUS_KID
LEXUS_KID's Avatar
Old 07-07-08, 12:30 PM
Lamchop21
Lamchop21's Avatar
Love it!!!
Old 07-07-08, 12:34 PM
dave11428
dave11428's Avatar
Looks sick!!!
Old 07-07-08, 02:30 PM
phillygs3
phillygs3's Avatar
Quick Reply: what a teaser
