Moon roof acting up
Old 07-07-08, 06:25 AM
RI-Lex
RI-Lex's Avatar
Default Moon roof acting up
my moonroof lately has been acting up, I've had it on tilt, and have pressed the button to close and nothing happens, not close or slide back nada usually I will have to put the key in the door and turn it to close it help has happen twice this week...
Old 07-07-08, 08:00 AM
sakataj
sakataj's Avatar
sounds like the motor going.........have you checked the gears to? if they striped or broke it wont turn. but sounds like the motor is starting to go bad!
Old 07-07-08, 08:03 AM
carbongs
carbongs's Avatar
souds like a burned resistor or something. check the connection behind the switch. maybe even grease is bad. if you can still close it with your key in the door then i don't think it is the motor. probably the switch. good luck
opisdfagjo
Performance & Maintenance
10-21-18 02:24 AM
airahcaz
07-02-17 07:04 AM
rvshy
02-08-17 03:56 PM
luda42688
04-22-15 11:31 AM
kikcaffine
SC- 1st Gen (1992-2000)
03-10-11 10:57 AM
Quick Reply: Moon roof acting up
