Bought a can of Seafoam.
hmmm...now I'm thinking of returning this stuff. The problem is:
1. I don't know of a local shop with a "Bilstein" machine
2. I had my Lexus dealer perform a fuel injection service and didn't notice one damn thing and it cost me $159+tax. The bolts on the throttle body didn't even look like they have been touched. Mind you they said that they take apart the TB in this service...what a bunch of BS.
I want to clean everything, injectors, TB, fuel lines, engine internals etc etc the most effective way without taking everything apart; obviously. Are there any other additive/cleaners like Seafoam that works better? What about "Restore", does that work good?
Not all injector service are the same. The cleaner used is more important than the machine used. Most fuel injector equipment will do virtually the same thing. You don't even need a "bilstein" machine. There are lots of other brands that will work as well..like OTC. Perhaps your engine is already clean enough to start with.
if you have a healthy engine and everything is properly maintained, I would use only 1/2 a can instead of the whole can. like alot of people said so far, if you dont have a healthy engine that gunk seafoam is breaking down might be patching a internal problem we cannot see. in that case your doing more harm than good, dont forget to change your motor oil asap after the treatment.
my points of use on my old vehicles were the brake booster line, going towards motor of course. pcv valves (silver 5 in long tubes on the engine covers) and last is the gas tank for injectors. its best to utilize all the spots mentioned because certain areas only reach a few ports. you might be cleaning the rear ports more than the fronts etc etc depending where detergent goes through. sorry if im confusing you guys, i have the idea in my head but hard to put into words.
don't get me wrong though, at lower mileages, maybe around the 75k range where things could get kinda gunky, seafoam is a great idea. or even when the car has been sitting for a while and you want to make sure nothing is varnished or what have you.
Sea foam works well..That's what every independent mechanic uses to fix the oil gel problem in the V6 Toyota/Lexus motors..
Also we did this on a honda B18C1 ...the thing was carbon free after doing it (we then built the motor up) about 500 miles later..(nothing was wrong) just wanted to see how through of a job it did
^^Werd. I've only used seafoam once or twice on my car. I went with a fuel injector service and my car improved much more than seafoam ever did. Plus it cleans more than seafoam itself. Lucas fuel injector cleaner provides nice lubrication. Got my noisy injectors quiet almost instantly!
Basically you can achieve this by running a really high concentration of cleaning agent in your gas tank, but I doubt anyone wants to do that. The fuel injector canister method provides faster results and the product gets applied more effectively.
