Bought a can of Seafoam.
#33
![No No No](https://www.clublexus.com/forums/images/smilies/nono.gif)
#34
Seafoam claims that their product will not harm O2 sensors. I have personally ran seafoam through the intake manifold of around a dozen cars and I have never had an O2 problem arise. Im not too familiar with the lexus computer and cel cycle but you would foul your spark plugs before anything else. You may have had a misfire due to a fouled spark plug. Just my opinion and experience.
#35
Sounds like carbon build-up on the 02 sensors. Seafoam
I know a local spot in Long Island to get the Bilstein and runrite done Nick.. Other locals had this service done and can attest to the results.. You can try CRC MAF cleaner (use this only) to clean the gunk off.. If this fails then you will need to replace the o2 sensors.. Good luck..
I know...I know
Also, for the last 1+ year my car has always gotten poor gas mileage; could my O2 sensors have been on their last leg and just dropped dead because of this cleaning?
If it did foul my park plugs then that sucks too because I have my Torque Maters in there and @ $12.50/ea this is getting pretty expensive (and stupid). What would fouled spark plugs look like? Would/could cleaning them do the trick? Sorry for all the questions Sean. My dad always says if it ain't broke don't fix it...I am starting to realize I should take on this philosophy.
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
#36
I know...I know
I shouldn't have used this stuff. So your saying I should clean the O2 sensors with the MAF cleaner? All of them? How many do we have? I know 2 of them are located on the Y-Pipe (one for each side).
I had some extra time on my hands and this is what happens.![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Here are Toyota Trouble codes for reference:
OBD II
P0100 Mass Air Flow Circuit.
P0101 Mass Air Flow Circuit Range/Performance.
P0105 Manifold Absolute Pressure Circuit.
P0106 MAP/BARO Circuit Range/Performance.
P0110 Intake Air Temperature Circuit.
P0115 Engine Coolant Temperature Circuit.
P0116 Engine Coolant Temperature Range/Performance.
P0120 Throttle Pedal Sensor Switch "A" Circuit.
P0121 Throttle Pedal Sensor Switch "A" Circuit Range/Performance.
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control.
P0130 Heated Oxygen Sensor Circuit - Bank 1 Sensor 1.
P0133 Heated Oxygen Sensor Circuit Slow Response Bank 1 Sensor 1.
P0135 Heated Oxygen Sensor Circuit - Bank 1 Sensor 1.
P0136 Heated Oxygen Sensor Circuit - Bank 1 Sensor 2.
P0141 Heated Oxygen Sensor Circuit - Bank 1 Sensor 2.
P0150 Heated Oxygen Sensor Circuit - Bank 2 Sensor 1.
P0153 Heated Oxygen Sensor Circuit Slow Response Bank 2 Sensor 1.
P0155 Heated Oxygen Sensor Circuit - Bank 2 Sensor 1.
P0156 Heated Oxygen Sensor Circuit - Bank 2 Sensor 2.
P0161 Heated Oxygen Sensor Circuit - Bank 2 Sensor 2.
P0170 Fuel Trim malfunction.
P0171 System too Lean.
P0172 System too Rich.
P0201 Injector Circuit - Cyl. 1.
P0202 Injector Circuit - Cyl. 2.
P0203 Injector Circuit - Cyl. 3.
P0204 Injector Circuit - Cyl. 4.
P0205 Injector Circuit - Cyl. 5.
P0206 Injector Circuit - Cyl. 6.
P0300 Random Misfire.
P0301 Misfire Detected - Cyl. 1.
P0302 Misfire Detected - Cyl. 2.
P0303 Misfire Detected - Cyl. 3.
P0304 Misfire Detected - Cyl. 4.
P0305 Misfire Detected - Cyl. 5.
P0306 Misfire Detected - Cyl. 6.
P0325 Knock Sensor 1 Circuit.
P0330 Knock Sensor 2 Circuit.
P0335 Crankshaft Position Sensor "A" Circuit.
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance.
P0340 CMP Sensor Circuit malfunction.
P0385 Crankshaft Position Sensor "B" NE2 Circuit.
P0401 EGR Flow Insufficient.
P0402 EGR Flow Excessive.
P0420 Catalyst System Efficiency below Threshold.
P0430 Catalyst System Efficiency below Threshold Bank 2.
P0440 EVAP Control System.
P0441 EVAP Control System Improper Purge Flow.
P0446 EVAP Control System Vent Control.
P0450 EVAP Control System Pressure Sensor.
P0451 EVAP Control System Pressure Sensor Range/Performance.
P0500 Vehicle Speed Sensor.
P0505 Idle Speed Control System.
P0510 Close Throttle Position Switch.
P1100 BARO Sensor Circuit.
P1120 Accelerator Pedal Position Sensor Circuit.
P1121 Accelerator Pedal Position Sensor Range/Performance Problem.
P1125 Throttle Control Motor Circuit.
P1126 Magnetic Clutch Circuit.
P1127 ETCS Actuator Power Source Circuit.
P1128 Throttle Control Motor Lock.
P1129 Electric Throttle Control System.
P1130 Air-Fuel Sensor Circuit Range/Performance.
P1133 Air-Fuel Sensor Circuit Response.
P1135 Air-Fuel Sensor Heater Circuit Response.
P1150 A/F Sensor Circuit Range/Performance.
P1153 A/F Sensor Circuit Response.
P1155 A/F Sensor Heater Circuit.
P1200 Fuel Pump Relay Circuit.
P1300 Igniter Circuit - No. 1.
P1310 Igniter Circuit - No. 2.
P1335 No Crankshaft Position Sensor Signal - Engine Running.
P1349 VVT System.
P1400 Sub-Throttle Position Sensor.
P1401 Sub-Throttle Position Sensor Range/Performance Problem.
P1405 Turbo Pressure Sensor Circuit.
P1406 Turbo Pressure Sensor Range/Performance Problem.
P1410 EGR Valve Position Sensor Circuit.
P1411 EGR Valve Position Sensor Circuit Range/Performance.
P1500 Starter Signal Circuit.
P1510 Boost Pressure Control Circuit.
P1511 Boost Pressure Low.
P1512 Boost Pressure High.
P1520 Stop Lamp Switch Signal.
P1565 Cruise Control Main Switch Circuit.
P1600 ECM.
P1605 Knock Control CPU.
P1630 Traction Control System.
P1633 ECM.
P1652 Idle Air Control Valve Control Circuit.
P1656 OCV Circuit.
P1658 Wastegate Valve Control Circuit.
P1661 EGR Circuit.
P1662 EGR by-pass Valve Control Circuit.
P1780 Park/Neutral Switch.
P1349 VVT System.
P1600 ECM.
P1633 ECM.
P1656 OCV Circuit.
P1661 EGR Circuit.
#38
2nd Autozone/Advance Auto. I wouldn't replace the spark plugs, sometimes the plugs will burn off the carbon that caused the misfire in the first place. Let us know what you find out. You have time to hit up Autozone today?
#39
#40
Some people say your other o2's will go out soon after but I disagree, just change the one that's bad if that's the case. I ran the universal bosch o2 sensor in my audi s4 (twin turbo) and they were just fine and lasted just as long as the oem ones. Around $65 compared to $150. Cant beat it in my opinion.
#41
Universal Bosch's are about 50 I think or so..
http://forums.bimmerforums.com/forum...d.php?t=324738
There's a way to test 02 sensors if I remember from my messing around with Honda dayz
#42
http://mr2.com/TEXT/O2_Sensor.html
and
http://ecomodder.com/forum/showthrea...nsor-2591.html
-To test the 02 sensors
and
#44
The CRC MAF cleaner works well on cleaning 02 sensors and of course MAF sensors but find out what the code is first. Personally I stick with Denso 02 sensors after several issues with bosch sensors in the past on other vehicles... probably just my luck more than anything else but thats just my preference. I would also only change the bad sensor if one is actually bad. I've used seafoam on several vehicles before (mazda 626, I30, chevy blazer) and I've never tripped a CEL code from doing so... unless of course I forgot to reconnect a hose or something... I have however had Lucas injector cleaner run on my 626 and Catera.. in both cases I had a CEL light almost immediately from bad precat sensors... most likely a coincidence but just sharing my experience. Get those codes scanned and let us know what comes up... and if DaShocker revisits this thread let me know where I can get that bilstein treatment done, for some reason I can't send PM's from my work computer.
