Im fed up, I need to get up to gs430 speeds.
HEy guys, I am tired of how slow my gs is. I wonder, what do I need, cheapest way possible, to get gs430 V8 performance? I was at the light one time with a430 by my side. I gunned it when the light turned green but I got smoked badly by the GS430. I was impressed at how fast it was. I was like![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
. I regret not getting a 430. As soon as my car is repaired, I am thinking about mods to the engine. Please help!
Well I'm going to say what everybody is going to tell you and that is turbo. However, you did say the cheapest way possible so I would suggest nitrous. You could also do what the IS300 guys are doing and that is to do intake/header/exhaust/camgear/piggyback/cams(newly released from brian crower) and you should be at or more than a stock GS4xx at the wheels. Will you be faster? We won't know 'til you try.
FWIW. In my opinion the GS300 is the better drive. The GS430 feels like a pig in the turns in comparison. Even with high performance tires the 430 just isn't as fun.
But if you're serious about going fast the upgrade path on the 2jz (as you likely already know) has far more potential then the UZ series V8's. You just have to be willing to spend the money. Of course...having the money helps too.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Just my 2 cents worth.
u know it's much cheaper to get power from a turbo than build ur engine n/a. i saw ppl selling aristo engine for under 2k after shipping on ebay. get one, dump it in. it will be as fast if not faster than the 430. if u try to get bolt ons, u will not get much performance unless u spend big bux.
One of the cheaper alternatives is to sell your 300 and get a 430. Nitrous kits cost around $500, give or take. However, it's refilling the bottle that adds up in the long run. Correct me if I'm wrong, but after I sold my kit (1.5 years ago) nitrous prices have gone up. It probably costs close to $50 to fill up a 10 lb bottle. I remember it used to be half that in '99.
nitrous will be your best bet. i am running a 125 shot now with headers, and exhaust. i can def hang with the stock gs4s. i am going turbo though hoping to leave them in the dust lol. it's gonna be a long and expensive trip. still doing research before i install everything
so i have thought about going the nitrous route with like a 75 shot... i never actually thought about the price to refill it. how many 75 shots would you get out of the average size bottle and how much to fill it up? also what are some of the mounting locations for the bottle that somewhat hides it without having to take out the spare tire and without having to sacrifice lots of trunk space...??
basically where could i put the bottle that my wife hopefully won't notice without getting rid of the spare tire? if you had a 12" small sub box in that little space in the trunk behind the rear seat is it possible to shove a bottle back there in that remaining little triangular space on the side of the box, but kinda up underneath the rear deck???
Speaking from my own experience, about 5 good 1/4 mile runs (decent pressure) until the bottle pressure dips too low from the optimum pressure (w/out bottle warmer) with a 10 lb bottle. That is spraying from 2nd gear and higher gears until the end if the track. A bottle heater, bigger bottle, or 2nd bottle (attached via a t-connection) is highly recommended to keep the pressure optimal.
When nitrous was a bit cheaper, I believed I calculated the cost (for nitrous only) to be around $3.50 a run (75 shot).
yessir, if and when i decide to do this i would def. spend the money to have it done proper, as well as the warmer and auto bottle opener and all. the spark plugs is cool, don't know much about the o2 sensors though but i'm sure i would learn if this is the direction i do go in.
i was under the impression that a 125 shot might be a little to powerful for my cars current setup and that a 75 shot would be a lot less strain on everything. i do hear what your saying about the added performance though and appreciate you putting it into perspective.
