Carbon Fiber trunk and hood ques.
#31
Forum Administrator
Fancy would be using treated lumber
#32
so bumping from the dead....i recently got my Seibon Cf hood and i would LIKE to get hood struts for it but it seems noone has them for the gs. i have gone through all these threads and emailed MOST the players in there who seem to have aftermarket hoods but im sure i missed some. i looked back and found a gb thread by figs and had been trying to talk to mike and hameed (who was the guinea pig for them) but mike doesn't have a solution as the 2 variations of hood struts he did make for the CF hood didn't work. one makes the hood bow up when closed and when he reduces the pressure some it wont hold the hood. it seems a new bracket is needed but as mike said he doesn't have a solution, which i would attribute to him being uber busy with more important things (like those amazing suspension pieces he makes) and the cost to make such a small run of parts probably wouldnt recoop his investment so its all good just need to find a solution
https://www.clublexus.com/forums/clu...strut-kit.html
https://www.clublexus.com/forums/gs-...-part-2-a.html
https://www.clublexus.com/forums/gs-...it-or-not.html
https://www.clublexus.com/forums/gs-...-registry.html
https://www.clublexus.com/forums/gs-...-the-hood.html
https://www.clublexus.com/forums/gs-...installed.html
so bottom line anyone have any hood struts they are using on a aftermarket hood that WORK?
Nice pick up! Are you going to drill and use hood pins? I have read in many areas that it is kinda dangerous to just rely on the stock latch; since the hood is so much lighter it can blow off a lot easier without hood pins. This is the only thing that deters me from picking up a nice vented CF hood.
#33
stock hood for a carbon fiber hood? The guy with a CF hood got a great trade, After owning a CF hood and trunk before i'd gladly trade them for oem lexus hood and trunk all day
Brian hadn't read through everything but i used blown hood and trunk struts on my stuff and it worked great.. when my friend bought new trunk struts i took his old worn out ones and they held up my CF one perfect..
I know alot of people like them, but man someone couldn't pay me enough to rock a CF hood or trunk on my daily ever again
#34
i didnt think about picking up someones blown hood shocks, i wonder how long it will take me to find those
honestly the clear coat has just been re-sprayed so its in pretty good shape but eventually i may just paint it black to match my car but even on a black car its very subtle........i couldn't do the trunk though due to the stereo and such
#37
Hey Brian, did you ever get the strut issue taken care of?
I'm still debating if I should install my seibon hood. Also I think I will be painting mine to match the rest of my car.
In case anyone was curious. I just weighed my seibon hood......25.5lbs. Has anyone actually weighed the oem hood themselves?
If not I will be weighing mine next weekend.
#38
im also considering painting mine to match but since my car is black it doesnt stand out so well but i have pondered it a few times
im interested to know how much the OEM hood weighs....
#44
The hood latches aren't for looks as much as they are for function. The CF hoods can blow up from a broken latch. After all they are only fiberglassed into the hood. I'm sure the looks of the car won't flow very well with a smashed windshield from the hood flying open on the freeway....
