will these wheels fit the 2nd gen gs300?
20x9.5F - 20x10.5R with +25 offset all around. and tire size recommendations? On Tein H-TECH Springs... approx 1.25 drop.
mods please move to right section if this is incorrect. thx.
Way too aggressive! The rear might be possible, IF it were 20 x 10 and not 20 x 10.5 and had rolled fenders with stretched tire set-up and a drop low enough to where the wheels camber in. The front is a different story, I don't think you'll be able to fit those no matter how much work you do unless your car is a widebody.
1.25" drop isnt a lot. eibach drops about 1".
i may be wrong, but, if you slap those wheels on with only a 1.25" drop, your wheels may be playing tag with cars next to you...not a good thing.
are you looking to tuck your wheels or for a flush fitment as Seize is referring to?
I'd pass on them unless you're planning to pick up a G35 coupe or 350Z. =P I've been in those kinda situations many times, and waiting for the right set was well worth it. Just my 0.02. =Þ
It's not impossible, but it will take a lot of work to make them fit. Are you browsing G35 forums? If so, look at wheels that came off the sedan. They have closer offsets to our car than the coupe.
