Need help Please! Car misfiring BAD
99 GS300,
I was changing the spark plugs for my buddy yesterday, and he decided to try and help. Well he moved the spark plug cables around after I had laid them out. So i'm assuming that they were installed in the wrong order.
Here is the what I'm trying to find out.
from front to back
plug #1 and #2
Plug #1 has what looks like a regular spark plug cable end on it
plug #2 has a box that uses a bolt to hold it in place.
plug #3 and #4
Plug #3 has what looks like a regular spark plug cable end on it
plug #4 has a box that uses a bolt to hold it in place.
plug #5 and #6
what I need to find out is how the cables and boxes are plugged into each other, what order.
for example - does the cable from plug #1 go to box on plug #6
my buddy mix them up and not the car has bad hiccups and misfires BAD.
the way I plugged them in was cable from plug #1 to box plug #2, cable from plug#3 to box plug #4, cable from plug #5 to box plug #6
from front to back
plug #1 and #2
plug #3 and #4
plug #5 and #6
The plugs should be linked 1-6, 2-5, 3-4
1 is the cylinder closest to the front of the car, 6 is the last one.
Coil Packs on 2,4,6
Pack 6 goes to plug 1, Pack 4 goes to plug 3, Pack 2 goes to plug 5.
Off the top of my head I think that's the order. I'll check the factory manual if that doesn't fix it for you.
Coil Packs on 2,4,6
