Lexus keys!!!!!!
#31
Well I think my problem is probably unique to most, as I dont have but one key and its the valet'. So if I were to get any keys cut for me, they would only be valet's too. I dont have any guts, controlers or keys. So I think the 445.98$ they are charging me to change out ECU, 3 new masters with controllers and a valet, is not a bad price at all. Esp when I found out that its over 1600$ normally WOW!![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
#32
#33
How do you post a thread? I just had a problem with the Stereo, interior lights and keyless entry on my 2000 lexus GS400 just stop working. Any advice on this please.
Thanks.
Thanks.
#34
Forum tools drop down menu or new thread tab.
#36
I bought 2 blank shells off ebay and got them cut at Ace for $7 each. I took the transmitter (guts) from inside my old broken key's shells and put them in the new shells.
Just call & ask your local Ace shop if they have a machine for laser cut keys.
If you have lost ALL your master keys (including the guts), you have an expensive problem. Its really bad if you have a 1998 or 1999 model GS and no master keys, cuz the computer has to be replaced along with the keys since its not re-programmable.
I've called ten different ACE Hardwares in the Atlanta area and none of them cut laser keys. They all said that there are not any ACE's that cut laser keys. Lexmatic pm'd me that the ACE that cut his key is no longer in bussiness. Maybe they went broke trying to recoupe the the cash they laid out for the laser key cutter!!
#37
This is a VERY old thread, but I could use an update.
I have ONLY one key, and it's the valet key. The original owner of the car lost the two master keys.
I want to get new keys with remotes, but I don't want to "brick" the car because I don't have a master key to start. I clicked the first link (end of page 2) and saw a master key for $100. But toy-lex.com is gone, so I don't know where to go from here.
If I need to get a master key or two for my car, what is the best/cheapest route. I'm also pretty tech-savvy so I can program things myself if given the chance.
Thanks
Thanks
#38
Thanks
Thanks
This was one of the first links for example:
http://www.a-1mobilelockandkey.com/t...questions.html
The exact year of your car matters too; later years allow the dealer to be able to get you a new MasterKey officially without flashing of the ecu; older years is where they need the unofficial methods and they may say we will only replace the whole ecu. So call your dealer too.
#39
How to tell if one has a valet key? I have two blank key's with "TOY" and an alphanumerical number behind it imprinted in the center of the circle for my 01. What do you guys mean by "ecu," is there a separate ecu for the key's? If so, where can I locate it so I can know if I have it and get the keys replace with 2 OEM/equivalent "or" eternity remotes.
#40
valet key is grey..the master keys have the fob remote on it..and there is a regular black key..if you only have the grey valet key..it cannot be duplicated cause of the chip in it..the keys are programmed to the main ecu of the vehicle..hence starter disable..anti theft..
#41
I have no OEM remote, black key, nor grey valet; just 2 black aftermarket non remote keys. Wellp, after I replace all my door lock actuators, and install new 6.5 speaker w/adapters I'll go to the dealer and get 2 remote keys, cut them then program them myself, and maybe keep my aftermarkets as my valet/backups. I'm tired of walking over to the car, stick a key inside the key hole and twist to open, to much work and to many fine scratches. I've never had a car with a remote and I want it that.
#44
Beware of cheap keys - they break and leave you stranded! The Eternity Key is the strongest replacement key on the market with a specially patented design for the most durability, and has a lifetime warranty too. It's the last replacement key you will ever need to buy. Ask your Lexus dealer for it by name, or check our website for dealers at www.eternitykey.com
