aftermarket projector HL with stock auto levelers
I know this is probably impossible to do but I was looking at these
http://cgi.ebay.com/ebaymotors/98-05...3286.m14.l1318
and was wondering if these could be used with a 99 GS400 pre wired with HID from the factory. In other words, could I bolt these on and still use the stock HID kit and it's auto leveler....or will I have to gut the whole lighting system and do all aftermarket HID (without the leveler). If so forget that.....
Is there any aftermarket projector headlights which support the factory HID kit and leveler?
Thanks for the info!
The autoleveling needs the motor that is in the original headlights. Also those projectors are made for halogen lamps, which are not made, aimed or focused right for hid lights. I would have someone retrofit a set of projectors from an S2000 or RX into your existing headlights. This way you will get a great look and the light beam will be correct.
You know whats ridiculous? You CAN buy a set with HID projectors, but they come with preinstalled HID's... I kept asking the guy, "are the projectors for HID's or Halogen?" he kept beating around the bush... ha... I forgot the point I was getting at!! LoL
