2001 GS-430 Power Mirror Switch
My power mirror switch seems to have gone bad for the left mirror. It still adjusts the right mirror, but I can feel there is no "Notch" between center and left any longer.
Any suggestions on how to remove/replace it, and possibly repair the existing switch before buying a new one ?
Thanks for any help.
--David in Dallas
--David in Dallas
Mirror Switch
I can pretty much tell it's the "multi-position switch" as you can feel the "notch" for the right, but when moved to the left, I feel no "notch" for center, or left. I feel the switch has broken, or something inside the switch has malfunctioned, and I need to find out how to remove the switch to get a closer look, or take it to a Lexus Technician friend who "May" know if he can repair the switch, but I don't know how to remove it from the dash.
Any suggestions, please ?
Thanks
David
Thanks
David
I think you can get at it by removing the under cover and then the safety pad. There are 2 screws for the under cover. Then 2 more for the hood lock. Then 4 bolts and one screw for the safety pad. You should have your battery disconnected before you start this.
Mirror Switch on GS-430
I'm afraid you are way over my head as I have no idea what a "under cover", "safety pad", OR a "hood lock" is, much less know how to recognize them if I saw them. THe miror switch is mounted just to the left of the "Change Tray", where spare change is stored, which by the way, I just discovered about a week ago after owning the car for over 3 years.
I was hoping I could get under the dash, see how the switch was secured from the back side and removed it, un-plug any harness plutted to it, and simply remove the switch for examination.
If you have any better suggestions for a "Novice", I'd appreciate any further comments.
Regards,
David
