How to remove stock radio/navigation unit
I think I've found it. Do you think this will work for a car with navigation?
http://www.carstereohelp.com/stereor...usGS400str.htm
You need to remove the ash tray, and the upper a/c vents where the clock is located. Both parts just pop right out with gentle prying with a flat head screw driver. Once both of them are out, you will see the four 10 millimeter bolts which need to be removed. Hope this helps.
sphereman
26
03-23-08 03:46 PM
