im a bit worried! help with wheel size
i just got a set of wheels and im abit worried about fitment now
here are the specs
Front: 20"x8.5" (+22 offset) with 245/35/20 tires
Rear: 20"x10" (4"lip) (+35 offset) with 275/30/20 tires
im lowered on a set of DF210s springs and GR-2 shocks about little less then 2 finger gap all around on stock 16s
will i be running in to any problems?
if anyones running a set of 20s with the same specs on df210s pics would be great
thanks
here are the specs
thanks
will the tires that are on the rims at the moment work?
cant afford to change out the tires
Front: 20"x8.5" (+22 offset) with 245/35/20 tires ?
Rear: 20"x10" (4"lip) (+35 offset) with 275/30/20 tires ?
thanks
thanks
i have this exact tire size on stock susp. 95% okay but as others stated the 245 would probably be what you want if you are lowered on those settings... therefore either invest in 2 new rear tires approx 400-600$ or raise the car back up...
is250rida
11-01-08 01:29 AM
