Tundra to GS400 Parts Interchange
Im sure you all already know this, but just in case someone doesnt here goes.
When changing T-Belt on my 98 GS400, I found out that almost all of the front engine parts for the GS400 are the same parts used in the 2002 Tundra V8.... I was able to purchase T-Belt, Water Pump, T-Stat, Crank and Cam Seals, and tensioners for about $300 or so retail (I purchased with my employee discount....) Just a heads up in case this wasnt common knowledge. All of the above part numbers cross to the toyota numbers for the 2002 Tundra V8 VVTi engine.
My Rav4 shares many parts with my GS400. For instance, the throttle pedal (linkage) which I had to replace on the GS400 some years back has the same part# as the one in my Rav4. The door locking mechanisms are the same across the Lexus/Toyota line as well. Just a plethora of parts are shared..
Yeah, I also am curious.. I know there are TRD superchargers for some of those Tundra engines.... how interchangable, if at all, would they be w/ a GS4, if they're the same engine...
Anyone?
Anyone?
