? Remove Yellow from foglights...
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Little by little I'm replacing any and all extremities on the car from lights to moldings to prepare for new paint job and make it look clean... well I made the mistake of purchasing the wrong fog lights... I've got the ones that have that yellow cylinder inside which give out the yellow and well its too late to return them... Is there ANY way to take them out? I want all 3 sets of HID's to be the same color!!! Thanks for any help.
dunno if u can do this but this is how the 1LS people do it, http://www.lexls.com/tutorials/lighting/fogs.html
thanks again.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Jokster,
Please try searching the forum for instant answers to your question![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Use advanced search to target the 2nd gen gs forum and use keywords like 'yellow break glass' 'remove yellow foglight' etc
Example threads I found in 10 secs
https://www.clublexus.com/forums/sho...oglight+remove
https://www.clublexus.com/forums/sho...ow+break+glass
It's not that hard to break the yellow out, just use a big screwdriver or something similar. Stick it through the bulb hole and pry slowly, working it around a little bit; you'll get it. Then you just have to shake the little pieces of yellow glass out. Make sure you didn't bend the shield out of place and if you did recenter it. You now have clear fogs.
Blasphemy to many here, but it's a lot less hassle for you than trading them; especially when they are brand new.
May I ask why you give the
