Has anyone used okada plasma coil booster on a GS??
I was reading through and looking for plasma coils for a skyline and i happen to found that okada projects produce a plasma booster ignition control for the 2nd gen GS.
Original site:
http://www.okadaprojects.com/usa/products_booster.htm
http://www.advancespeedshop.com/okad...1s-p-7213.html
OKADA Projects - Plasma Booster (Ignition Control), for Lexus GS300 98-05
The Plasma Booster is a high power amplifier which drastically boosts ignition coil current.
The Spark Increase is dramatic with the Plasma Booster and you can expect 100-percent increase in Spark Current, which is the amperage going to the spark. With such an increase in spark current, the ignition process is faster and it also creates a faster burn, thus leading to more Horsepower and Torque. Complete ignition decrease the incidence of "hot spots" in the combustion chamber and lowers the risk of detonation.
- Easy to install, only 2 wires on distributor type ignition.
- 100% secondary current (Spark Amperage) increase
- 4 Times Spark Energy Increase for the initial spark discharge
- Compatible with all OEM components
- Compatible with OBD-II (On-Board-Diagnostics)"
2GSTony
12-12-14 11:46 AM
