CEL and VSC and VSC off light came on again!
Old 08-07-08 | 03:16 PM
pitmanr200's Avatar
pitmanr200
Default CEL and VSC and VSC off light came on again!
I had these lights come on and the car was running fine about 2 months ago. turned off car and on and they went off. no problems for about a month and it came on again, but didnt go off with turning car off and on. Car is running fine. took to autozone to read code. he said it was idle controll sensor i beleive it is. i reset ecu and no problems for about a month untill today. was going down the road and they all came on again. car is running fine. Its getting aggravating reseting ecu and having to reprogram everything. Im leaving it on being Im going to get a tranny flush tomorrow at my local mechanic and he is going to look at it. what do you all think it could be?
Old 08-07-08 | 04:25 PM
BCP43002's Avatar
BCP43002
It would be nice to know what the code number was. All I could find was code PO505*3 that was related to the Idle Control System. Items that could cause this code are problems with the air induction system or the electric throttle control system.
Old 08-07-08 | 04:37 PM
pitmanr200's Avatar
pitmanr200
p0505 is the code.
Old 08-07-08 | 08:26 PM
pitmanr200's Avatar
pitmanr200
nobody else has a clue. I was told to clean throttle body.
Old 08-08-08 | 07:53 PM
ElitistK's Avatar
ElitistK
tps might be out of calibration.
Old 08-08-08 | 08:26 PM
PHML's Avatar
PHML
Master Thread Closer!!
r u using an aftermarket air filter? Time to change the air filter....also u should clean your MAF sensor...I found mines was dirty as hell after using K&N filter.
Also, clean the throttle body....then reset ecu overnight.
Old 08-09-08 | 12:04 AM
pitmanr200's Avatar
pitmanr200
ok i will try that. filter is brand new. but i will clean the other stuff. how do you suggest cleaning tb and mass meter
Old 08-09-08 | 12:11 AM
pitmanr200's Avatar
pitmanr200
ok i will try that. filter is brand new. but i will clean the other stuff. how do you suggest cleaning tb and mass meter. stock air filter
Old 08-09-08 | 03:44 AM
PHML's Avatar
PHML
go to autozone, checkers, or other auto store...they should sell MAF cleaner and TB cleaner.
Old 08-09-08 | 10:27 PM
pitmanr200's Avatar
pitmanr200
ok thanks
alot
KRobbins
Maintenance
07-03-18 10:57 AM
O1GS43O
05-09-13 11:07 AM
RC1047
02-03-11 01:53 PM
CallmeQ
GS - 1st Gen (1993-1997)
09-26-09 01:19 PM
