Turn Signal Halos
This is a request for help from anybody that knows electrical... I have angle eyes or "halos" on my headlights, and I had this grand idea of making them flash with the turn signals, as well as the side markers... Problem is I want them to be on constantly but flash when the signal flashes. Is there any way of doing this, or does anybody know how to wire something like this up? I think it would do everybody well just to even know how to make the side markers flash with the turning signal while remaining on when the turning signal is not activated. If anybody know how to help I would love you forever
BTW I hooked up the halos directly to the turn signals power, and it looks sweeeeet
Thank you
-Joe
Thank you
-Joe
I have the ebay halos, so the connector plugs into the stock connector that had the turn signal and the extra light that used to be in the high beam housing. The angel eyes run off the old (can't remember the name) extra light, and the turn signal still plugs into the same port... By any chance, do you know the name of the item? Every place I go to the guys that work there know nothing more then the guy at the drive through window at mcdonalds haha...
Thanks again for all your help on both my posts carbongs and everybody else!
-Joe
-Joe
What I was thinking was run the halo ground wire through a realy that holds contact until its triggered by the turn signal. When the signal turns on it would trigger the relay to break contact and turn the halos off. When the signal goes off the relay regains contact and the halos would turn back on. They would flash together but at alternating times. Thats the simplest way I thought of.
cut the connector off the halo line that runs to the daytime running light. strip the wires for the turn signal bulb, splice them in (i'd recommend solder, but you can cut the turn signal wire, twist it all together or use a terminal cap), wrap em up nice nice and there you go. however, this won't keep them on with your parking lights, they'll only flash on when the signal goes.
i did this when i was in my rice stage (
) 99 maxima, had blue washer sprayer lights wired with my turn signals.
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
That is not what I am looking to do, just to see how it would look when they flash, I swapped the two connections and saw that they work as blinkers and now want them to continuously be on, but when the turn signal comes on, I want them to flash, as well as my side markers. But thank you
-Joe
-Joe
-Joe
-Joe
