how do you take the sub out
under the head rest there are slits in the leather 2 bolts. 1 on each side. the back seat comes out. take the rear deck cover out and the sub is accessable. hope this helps.
Fairly simple process.
First, you have to remove the seat cushions of your back seat. Just pull up really hard on the bottom of the cushion and it should come out of its clip. Do it with both left and right cushions. After that, there should be (4) bolts holding down the back seat at the bottom. After removing them, take off the bolt underneath the headrests. There should be a flap opening to them after you remove the headrests.
Next, you have to remove the pillars on the side. I'm not sure if you can take off the rear deck without removing the pillars. Just pull on the pillars until all the plugs come out. After, there should be three clips holding down the rear deck. Just pop those up and pull the rear deck out.
After you pull that out, there will be 4 bolts holding down the rear sub in the back. If you have some kind of lining underneath, you will have to lift it up and look for them.
If you have these weird clip things on the rear deck like I did, you just pull them apart at the bottom and a bolt should show up underneath them. Just take that off and then remove the rear deck.
Hope this isn't too much of a mouthful. Good luck! Not sure if I got all my numbers right though.
