toyota aristo blue mirror lens
like i said, unless im reading his auction wrong... those are jdm toyota oem blue mirrors for the 98-05 2nd gen.
TOYOTA ARISTO
LEXUS GS300/400/430
(1998-2005)
BLUE WIDE MIRROR PANNELS
CONDITION: Brand New ( Toyota Genuine Parts )
QUANTITY
1 set ( Driver and Passenger side )
COLOR: Blue Mirror Lense
FITTING: LEXUS GS 300/400/430 JZS160.161 ( 1998-2005 )
NOTES
* REPLACEMENT TYPE
* SIDE CLEARLANCE IS MUCH WIDER THAN NORMAL MIRROR PANEL. (QUATER PART ON EACH SIDE PANNEL HAS WIDER ANGLE)
* REDUCING THE HIGH BEAM FROM THE REAR VEHICLE BEHIND
* ONE PIN ON THE BACK LENSE PANEL TO CONNECT HARNESS (ONLY ONE PIN EACH SIDE) FOR HEATED MIRROR USE (SEE PIC)
Super Hard to get in the US!!!
if he's lying about them being oem toyota, or being a direct fit for the gs, zeroism probably wouldnt be able to maintain his 100% feedback rating.
actually.. after all this talk about these mirrors, im going to buy a set from him ill let you guys know how it works out.
TOYOTA ARISTO
LEXUS GS300/400/430
(1998-2005)
QUANTITY
NOTES
* REPLACEMENT TYPE
But it's not for the 16 Aristo. Most, if not all the Aristo owners in Japan I know use the OEM 17 Crown Athlete side mirror. It's like 3000yen (30bucks) IIRC. And everything should be a bolt on including the pins (dunno if all 17 Crown Athletes had heated mirror option though).
I have an 03 GS430 with Nav and ML and my side mirrors don't auto dim either. Mine is either broken or it doesn't auto dim. Surprising since my 99 LS had auto dimming side and rear mirrors. A little off topic, but does the side mirrors tilt down as well in reverse? My 04 RX and 99 LS did, but I can't get my 03 GS mirrors to tilt. Mine could be broken though and maybe that is why it doesn't auto dim either.![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
I ASKED A TECH HERE AT WORK AND HE TOLD ME All Gs430's Came With Side Auto Dimming Mirrors, There Controlled Through The Center Mirror.
it is insane... ive paid less to ems things from japan then i have for some stuff just a few states away which ups would still take 4-5 days to deliver...meanwhile ems blows over here and some stuff has even showed up on saturday mornings BEFORE my regular mail at like 9am lol.
