AC issue
AC issue
Ok so ive done a bunch of searching and found a few theads on my problem, but not exactly. I turned on my AC this morning and the drivers side is blowing hot air, while the passengers side is really really cold. Any help would be greatly appreciated
try researching a blend door........i have the same prob but opposite. mine is ONLY on heat.........and only happens on passenger side sooooooooo guess i need a blanket in the car for them? hahaha. do u hear a click and a whirr or some kind of electronic noise sometimes on start up or when u turn th air off and/or on?
yes thats the noise i meant. its a blend door....they located under the dashboard by the glovebox. this is what electronically switches the air from head to feet to both and from hot/cold. sounds like yours is doing like mine is and sticking. i haven't bothered replacing it yet as mine only does it on heat and only on passenger side. (sorry sweetie i dunno y u cold im nice and toasty ) i will be doing mine in the winter. also there are like 4 of them under there.....i have heard this is quite laborious....as i think the glove box will be coming out and someone said they pull the dash. mines starting to act up again so i might be doing my own shortly. was ALSO told sometimes its just the gear arms on the synchro of the blend door and my mechanic said he might be able to replace just those. let me know what u do man
Both sides get heat when the heat is on too. where can i find more info on the blend door?
you have been directed down the right path. if you are not comfortable with at least pulling the glove, changer, and amp to allow for further diagnosis, then you will have to take it somewhere. fellow members have answered the what, and it is up to you to answer the why
ok so i did some research on some past topics..........
https://www.clublexus.com/forums/sho...nd+door&page=2
https://www.clublexus.com/forums/sho...ght=blend+door
they just aren't very helpful. can anyone else give me some insight?
Joncash730
07-01-24 02:59 PM
Lexusman79
07-27-18 01:17 PM
