popping noise
hi u guys..im getting this popping noise almost everytime i reverse my car and then step on the brake...im trying to figure out what it is since it's very annoying....anyone have any ideas??? thanks for your input
Brake pads moving around...there's a TSB to put grease on the pad clips....just collects dirt and makes it worse. Either try and clean the clips or replace them.
Constant battle!
Constant battle!
It's normal for the pads to move around in the caliper. They will click ONCE every time you change direction(foward/reverse). If it continues to click in the same direction after hitting the brakes two times or more then its not normal. There's about 1-2mm of play in there. If you're getting a constant clunk all the time, epsecially on turns and inclines...then that might possibly be the ball joints.
en11871
24
01-23-13 06:21 PM
topgun129
05-19-12 06:22 AM
