My Gs300!
Has anyone had a problem when your check engine comes and off. I have an 99 GS300 and the check engine light comes on and then later goes off. I took it to the lexus dealer for an oil change and see if the can detect what was going on. By the time I did the light went off. Crazy
Has the Lexus dealer tell you what causes this or did they hit you with a big fat bill of what was suppose to be done 3,000 miles ago thats why the light came on
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Loose/bad gas cap.
Loose/bad air filter.
Bad sensor.
ECU might need resetting.
Bad sensor.
Borderline or low coolant level can cause the check engine light to flash. One of the first gens that I test drove back in Jan threw the check engine light during the test drive and it was caused by a low coolant level.
