dimming lights.
Well, for a while my lights (inside and out) have been dimming when I'm listening (probably from the sub). I've already replaced the battery and I'm thinking maybe I'll throw a bigger alternator (but I cant find any, any suggestions?)
Does anyone know what would keep my lights from doing this?
My set-up is;
Eclipse avn 5435 nav
Diamond audio comp. speakers
JL amp 300/4 (for interior)
Kicker VR10 Sub
and I don't know what kind of amp is running the sub.
Any input is welcome. Thanks!
My set-up is;
Kicker VR10 Sub
you need a capacitor. 1 farad for every 1000 watts you're running. the cvr10 is only rated for 300rms and 600 max, so you're safe if you get a 1farad cap, and on the borderline if you get a .5 farad cap. you wire the cap inline between the amp and the battery. The cap stores up extra power and delivers it back to the battery when the bass hits so that the power isn't drawn from your other accessories.
If you haven't installed the cap yet, I'd try upgrading the big 3 wires under the hood to larger guage wire first. Search on it in the audio section for more details, but basically upgrade the alternator-battery, battery ground, and engine ground wires to bigger wires. The small factory wires act like a bottleneck and kind of choke the electrical system a little bit. Changing them will make sure power is flowing freely through the whole system.
This will frequently eliminate minor dimming, and cost you alot less than the cap; plus you're actually fixing the problem instead of putting a band-aid on it.
Dont buy a cap just yet. Do what Kyle said first.
I have more power than you, yet I never had dimming problems before. The big main 3 wires were the first thing I did when I got my car. I've gone through lots of setups before and never had to use a cap. Capacitors are used to stabilize the voltage, but if you never had power to start with (alternator), then a capacitor wont benefit you much. In any case, you need to start out with sufficient wiring first. In any case, having a larger capacitor can be a negative thing. A capacitor is just one more thing for the alternator to charge.
YupImJOee
09-30-07 05:30 AM
BLexACK LS
12-20-02 03:23 AM
