L-Tuned wheels help.
I just got me a 01 l-tuned 2gs a couple month back and i am looking to lower her soon. For now, i am going to rock the l-tuned wheels....and what iam wondering is, what size wheel spacer will i need to push the stock l-tuned wheels out "flush" or at least fitting a lot better than they do now. Thanks for any input or help.
(example)
(example)
In case you are wondering, the specs are 18x8 +45 and 18x9.5 +45. You should lower it to where you want and then see how "flushed" you want to decide on spacers. There is also the issue of shaving the fenders to get even more flushed. If you do that , it will affect the spacer size.
I have these on my car now, lowered on Tein CS, and unless you want to shave you "might" be able to put 5mm on the rear and 15mm in the front. Mine fit pretty flushed in the rear with some gap in the front but there is a whole heck of a lot of fender wheel protection to remove if I want the front flushed. Running spacers you will need to run pretty significant negative camber.
(example)
(example)
kyle3481
06-17-01 12:06 AM
