Help to find...
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
how to remove gauge cluster. I was searching for hours and can't find anything usefull. I remember reading some guys' thread about how he removed gauge cluster just for the hack of it with pictures. Can you please help me find something useful?
Thanks.
Thanks.
it should take u 5mins to remove it. its pretty straiht forward
here is how...
grab and pull the bezel outwards. its not held in place by anything. it just clicks in. It is however connected to a harness which you will see when you pull it out. disconnect/unplug that.
then you will see the guage cluster held in place by 4 screws :2 on top and 2 at the bottom.
unscrew those and pull outwards. its not clicked into anything since it just had the screws holding it in.
so pull outwards and unplug harness connected to the guage cluster.
wholla...u done.
here is how...
wholla...u done.
Thanks, did that, was pretty straight forward. I wanted to change the color of gauges, but then realized that there's no bulbs or LEDs..... it's electroluminescent. Oh well..
