HID Fogs Don't Work...Need Help
Old 09-10-08, 11:09 PM
ISFjimmy
ISFjimmy's Avatar
Originally Posted by GCOP
87 to battery positive
85 to ground
30 to your ballasts
86 trigger from your factory fogs.
yeah i saw. ill do that sometime this week.
Old 09-10-08, 11:39 PM
jamodeo
jamodeo's Avatar
I had this same problem.... Take the plug that goes into the OEM light and turn it around so it goes in the 'not easy way' and push. The polarity is set incorrectly for that pin config. So if you just flip it around they will work just fine!
-Joe
Old 09-11-08, 06:07 AM
Infamous 1
Infamous 1's Avatar
ill try some of these ideas when i get back home. Thanks a lot guys for all your help. I will keep you updated.
Old 09-11-08, 03:37 PM
1GStoEnvy
1GStoEnvy's Avatar
Location: ~SIMPLY TUCKED~ scraping the mean streets of L.A.
what you need to do is switch the polarity of the pins in the connector after that if will work for sure.
Old 09-11-08, 03:56 PM
DarKnight
DarKnight's Avatar
You just need a wiring harness. I had this same problem when I first installed my HID's. Once I installed the wiring harness the lights started right up.
Old 09-11-08, 04:22 PM
Infamous 1
Infamous 1's Avatar
I turned the plug around and it works perfectly now. Thanks everyone.
Old 09-11-08, 04:39 PM
1GStoEnvy
1GStoEnvy's Avatar
it's because our cars runs on reverse polarity so that's why it didn't work at first.
glad to see that we helped you solved your problem
Old 09-11-08, 05:55 PM
Red Bully
Red Bully's Avatar
hid relay kit is what you need just buy it. Its cheaper in the end.
Deegee
03-16-11 01:11 PM
imports4me
03-25-10 11:17 AM
DarKnight
Lighting
36
08-27-06 09:05 AM
rominl
Lighting
06-13-03 01:05 PM
Quick Reply: HID Fogs Don't Work...Need Help
